If you are exploring both Multiwii and Megapirate, suggest that you maintain 2 Arduino Compiler in 2 separate directories, e.g. one for MultiWii and one for MP. Before you flash, you have to erase the eeprom and reset the FC. FYI, I don't think it is necessary to rearrange the cable or connector. However, do note that the PID setting is totally different. The tuning procedures may be slightly different too. I am waiting for the AIOP 2 FC and will be setting this up with MP too.
flight controller
Originally posted by perdification View PostHmm, could this be affecting the connection between Mission planner and the crius board?
I'll go back and have a go at it. Thanks!
Are you connecting ONLY the FC... or did you plug in other accessories.... if you have issues.. maybe just disconnect everything else and start from scratch.
That is the only thing which I could spot from the config.h
V2 and V1 is slightly different due to the new rev of the 2560 chip.
Originally posted by Kaen View Postdoesn't look likely... PPM is only going to be a factor if you have issues connecting your radio RX/TX isn't it?
Originally posted by wengwah View PostIf you are exploring both Multiwii and Megapirate, suggest that you maintain 2 Arduino Compiler in 2 separate directories, e.g. one for MultiWii and one for MP. Before you flash, you have to erase the eeprom and reset the FC. FYI, I don't think it is necessary to rearrange the cable or connector. However, do note that the PID setting is totally different. The tuning procedures may be slightly different too. I am waiting for the AIOP 2 FC and will be setting this up with MP too.
By the way, I've tried changing the PPM stuff you mentioned previously, didn't work.
Thanks for all the help so far wengwah.
Thanks Kaen.
Originally posted by perdification View PostOkay, I will try and do these steps: 1) Disconnect everything from the FC. 2) Plus in USB cable. 3) Erase EEPROM. 4) Do a reset on the FC. 5) Proceed to flash MPNG. 6)Test it out!
Thanks Kaen.
Thanks for all the help so far.
Originally posted by wengwah View PostMy 2nd AIOP v2 is arriving this week. Will test this out.
Originally posted by wengwah View PostI bought my 1st AIOP v1 last Dec. Tested and satisfied with the performance. I am getting the 2nd FC for Arducopter for UAV. Once tested, I will install on my Bixler 2 for UAV test flight.
