I think, i got it.
1-I connect to Assistant Software Version V2.10.
2-I got to "TOOL" and select Restore default setting.
3-Select "check IMU Status"=OK.
4-Select "Advance Calibration", Waited almost 3 mins
5-Go to the top menu and select "basic" and "advance" configuration.
Note***( Everything is back to zero. I set everything on each page and press ENTER)
Unplug the usb and cycle the power.
6-Calibrate the GPS and unplug the power.
After that when i replug the battery, it do a self check, follow by yellow bling for 1set then it continue with 2 green and 3 red all the way.
All this around less then 20 sec. And i can arm The motor....... Woo Huuuu!!! Cheerssss!!!
I can't fly it in the house since i dont know how high the Auto take off mode will hover...
I hope my 550 can fly nicely or better then the old FW.....
