Originally posted by bozora
View Post
SGDRIFters Drift Into Quad
Originally posted by MarketMaker View PostA big thanks to speeder and bozora yesterday!! learnt a lot yesterday + tuning of my quadcopter & cheap & good props.
Originally posted by bozora View PostNo sweat MarketMaker,,,pls note that the firmware on your Naza M is the new version3.0. You will need to use the new Naza Assistant 2.1 should you want to adjusting setting moving forward. Download the assistant from DJI Innovations.
Originally posted by tom99sg View PostI'm confused. So the latest firmware is 3.0 and not 2.1, visors?
1) The Naza Assistant Software.. the current Naza M uses software Naza Assistant 1.8 and the new Naza M V2 uses Naza Assistant 2.1
2) Then there's the firmware inside the flight controller....the current Naza Flight Controller has the 2.02 FW inside.
On the new Naza M V2 it has the new 3.1 FW inside the controller.
You can upgrade the firmware of your current Naza Flight controller from 2.02 to 3.1.
This way you get to enjoy new features such as the semi auto takeoff and enhance stabilisation during hover. If you fly a hex you also get to enjoy the new enhance failsafe (one prop or motor failure still can bring back your hexa).
You also need to download the new Naza software Assistant V2.1 for this to work.
Hope that clears the air.
Originally posted by bozora View PostMy apologies for the confusion...allow me to explain....there are 2 parts to it
Thank you again bozora to upgrade V2.1 FW my quad.
Tested with V2.1 and flew aggressively on (Att, GPS, head lock) speeder saw it.
Super smooth, firm and stable on flight with controll (pitch roll 110 gain) , experience stronger wind condition within one feet drift.
Very satisfy and great experience to have V2.1 on my naza-m.
Will get you a nice meal bro bozora...two thumbs up
Originally posted by zennith View PostThank you again bozora to upgrade V2.1 FW my quad.
Generally the new fw works well with the current naza m mounted on quadcopters.I have also successfully configure it for marketmaker, good stable flight.
What's interesting though is fw 3.1 din quite work on an F550 hexa (error showing on vue with rapid orange flash). Did a 3.0fw upgrade from 2.02 and it worked. Height holding is a little off at manual att..so still required further fine tuning.
