Originally posted by blueangel
View Post
Getting Started
Been trying to get the swahplate to be level....but after trying my best to level the swash plate, the "blue" light is still not coming out at the recommended setting....this is even more fustrating when it come to setting the swahplate limit using the microbeast...the left and right aileron doesn't seems to be even (despite leveling the swashplate to the best of my knowledge)....plus the light doesn't come out as blue based on the recommended setting....
Originally posted by vintcs View PostU will evenly require everything to be equal on both side. Why not set it up once correct and don't have to redo again. Both side not equal pitch might be swash plate not level, swash plate travel not even or the cyclic ball links dimension are out.
Do you have any subtrim in the transmitter?[:]=-[Hangar]-=[:]
Trex 450L Dominator
Goblin 500
Spektrum DX9
"Airplanes fly while helicopters simply beat the air into submission."
-RR Heli Quotes
[SIGPIC][/SIGPIC]
Originally posted by Redtwilight View Post+1 Totally agree with this. Set it up properly 1x good one and never have to worry about it again. Otherwise you'll always have that 'Is that okay?' thought.
In fact the only setup issue that I am currently facing is getting equal + and - on the Adjusting the cyclic swashplate limit...whereby the + can be much more than the - angle...Any idea what is the cause (any changes that at this point it is still back to Adjusting the swashplate servo centering being poorly setup?
Originally posted by ATR76ers View PostWah...Your advise greatly helps...Yes...this is one of the problems that I am facing with the setup...always not able to get equal pitch....didn't know can set it as what you have mentioned...Will give it a try tonight...any other advise from others will also be greatly appreciated...Thanks for guiding a newbie.....almost wanted to give up if not for all the encouragement and support....
Beginners pitch are pretty conservative.
-5 to +10 more than enough.I'm Remotely Controlled ...
You may want to dismantle the horns first, and work backwards like i did.
From your gyro software, click on the step where it ask you to level swash to 0 degree and then with pitch gauge, install the servos horn back to the servo and ensuring it still maintains somewhere around 0 degree pitch.
If Beast doesnt have 0 pitch step ( since i dont use Beast ) , then work around by clicking on the +8 pitch step, then set the servo horn such that the blades are 8 degree or thereabout.
Once secured, you can go back a step to check the +12 and -12 and see if it improves.
Remember that on some gyro, afaik robirds and gpros, they requires you to point the blades either to the sides or to the front in order to correctly set the +/- 12 and +8 pitch position.
Pointing it at an oblique to the fuselage often gives inaccurate pitches.I'm Remotely Controlled ...
Originally posted by blueangel View PostYes i think this is still your servo horns not centered.
Physically centering the servo horn will reduce the amount of gyro subtrim needed to get the swash flat.
After that, check your tx pitch curve and make sure that it's -100 ~ +100.
Use the channel monitoring feature (most TXes will have it) to get 0 output pitch at mid stick.
Mount the pitch gauge on either blade (You may do this with the blades parallel or perpendicular to the heli. I prefer to have the blades sticking out the sides of the heli.)
If at this point the still heli has +ve pitch, drop all the swash links by the same amount of turns to lower the swashplate evenly.
AKA pop out the pitch servo link, turn clockwise by 1 full turn, pop back, pop out aile servo link turn clockwise etc.
After finishing that for all 3 servos, measure the pitch at 0 output pitch again.
If it's negative now, increase all swash link lengths by half turns at a time. Should be able to get v close to 0 pitch then.
Check the max and min pitch again.
If still off then it means that your blade grip linkages are too long/short.
Adjust them and repeat raising or lowering the swashplate till you get ~0* at mid stick.
After you get the pitch on 1 blade right, rotate the rotor head 180* and put the pitch gauge on the other blade. Adjust the blade linkage to get the same pitch as the previous blade. This will help blade tracking, thus increasing stability and reducing vibes. If the blades don't track well, i.e. one has more pitch than the other, it'll be like uneven flapping and that blade will produce more force gg around, causing the heli to shake.[:]=-[Hangar]-=[:]
Trex 450L Dominator
Goblin 500
Spektrum DX9
-RR Heli Quotes
[SIGPIC][/SIGPIC]
Originally posted by ATR76ers View PostI very paisey to waste their time in helping me when they are there to spend their precious time flying the bird.....
Hope that they will not mind me wasting their precious time.....
anyway, this hobby should be our therapy and not the reason why you need therapy. Many of us loss precious sleep due to unknown issues and are always on youtube in search of solutions...sounds familiar?Heli-ADDICTION:
Originally posted by feudallordcult View Postwhere got waste time? if can share our experience to benefit others, we will try to help.
