New Cat
    I think this boat similar to bro siggy hpr but with a different setup
    http://www.youtube.com/watch?v=U0bm_...eature=related
    My fleets
      Thanks!
      This one got the same set-up. It belongs to a friend from Italia.
      2013 RC4WD International Team Driver
        Fail Safe Unit
        Here is my 5A Voltage Regulator (with a somewhat "scale-looking") Fail-Safe Switch.
        With the Fail Safe Key Detached - 5V-6V Power to RX is Active
        With the Fail Safe Key Attached - Power to RX is Cut
        Hopefully the System effectively minimizes the chance of getting injured by the sharp propellers, when a need to change props arises or a need to do Rescue Operations.
          good afternoon siggy,
          It happened to one of my forum friend in France with propellers from Iota rc. How to say, yeeeessssss, it's sharp and painful
          JET
            JET
            It seems that Fail Safe Devices is fast becoming a Standard Safety Requirement in E-Powerboat SAW Competitions in Europe.
              Voltage Regulator/Fail Safe Switch - Installed and Functional.
                Very Cool! better looking then using AWG wires that sticks out
                Warpath Wong
                  hey Sig
                  Is that a tygon cooling tube?
                  My fleets
                    Hello Siggy,
                    may i see (if you have already done) a pair of 'lips' under your canopy that will slide under the deck?
                    Just curious how will you secure the lips to the underside of the canopy
                    thanks
                    Warpath Wong
                      Thanks. Much easier to mount - just 1 hole then fasten with a nut.
                        hey Sig
                        Yes, Tygon High Performance Engineering Plastics.
                          Hello Siggy,
                          thanks
                          No "lips", just (4) countersunk screws and tape. Maybe 2 more screws as recommended by ManuelW.
                          Hot set-up will be 5S, (and if temperature is good) then 6S max.
                          Guys, any feedback on Revolectric 5S/6S 5000 60C, please?
                            I have that one before also use for cooling, I tell you its not good for cooling, anytime it break and flooded your boat base on my experience and should go for the silicon type.
                            My fleets
                              That's genuinely surprising. What's the cause of your hose to break?
                                I don't know what cause it, seem it just that I can easily break it and thats why I stop using it
                                My fleets
