New Cat
    Originally posted by Mel279 View Post
    I don't know what cause it, seem it just that I can easily break it and thats why I stop using it
    NTC Hobbies sold rolls of Tygon tubing to their customers without a problem.
    Maybe it is a different type of Tygon engineering plastic tubing -- although it is difficult to be certain with lack of information, you may have used the wrong type? Or maybe it did not have a tight/secure fit, the plastic tubing internal diameter was slightly bigger than your ESC cooling tubes -- you may have use the wrong size? Or maybe the clamps you used to secure the plastic tubing gave way due to excessive water pressure - were you going extremely fast? Or Maybe the tubes got exposed to excessive heat to get the plastic tube to get brittle then crack, crumble, and/or break -- did you have a fire when this happened? or Did you have the chance to rule-out other Causes of the flooding -- might be hairline cracks/holes/small leak in the Hull or a Combination?
    Anyways, we are doing a couple of Test-Runs to make sure all is Ready to Go. Thanks for the heads-up on a potential issue/problem.
    2013 RC4WD International Team Driver
      I always buy them(plastic tubes) from NTC but i not sure what are they. I have not encounter any problem till date. Further more these tube are freaking tight once they are fitted to the cooling nipples i believe the plastics sort of contract due to temperature overtime.
      Not cheap you know per meter heehe
      Warpath Wong
        I have some that are unused also break easily, bought it cheap from HK same color as yours and yeah it a cheap low quality tube.
        My fleets
          Sounds like you got hold of some knock-off or factory Rejects.
          I figured that these should make for excellent cooling lines. Glad that they remain to be problem-free and agree that it is a tight-fit. Very encouraging, if it holds True when it matters.
          For this Project: Performance is 1st, Reliability is 2nd, and cheap is a HUGE Bonus.
            Hello Siggy,
            which servo are you using how many KG?
            Warpath Wong
              Originally posted by Battle fury View Post
              Hello Siggy,
              KOPropo PDS-2512 ICS
              Volt: 6V
              Torque: 10.8kg/cm
              Speed: 0.16s @ 60°
              Ballbearing: Double
              Plug: Gold
              Gears: Metal
              Weight: 46,5g
                You have a PM
                Warpath Wong
                  You have a PM
                  Read and Replied. Thanks!
                    Thinking of doing a Run during the CYN.
                      Keep us posted of the date and time here
                      Warpath Wong
                        I need to figure-out emergency rescue plan. I was thinking of getting a Rescue Boat, ideally a 1-man rubber boat.
                          Toy r us has those said what u are look for. They sell together with those t-handle air pump but u may wanna look into electric air compressor small pump
                          Warpath Wong
                            Are you sure I won't need another rescue rubber boat to rescue me, just in case the Toys-R-Us Toy Inflatable boat Fails?
                              Happy CYN to ALL!
                                Been quite busy building-up the New RC4WD Trail Finder 2. But that's all done soon. Will get back to doing the Maiden of this HPR, still looking for a rescue boat and crew, to make sure all ready and safely executed.
                                Thanks for your patience.
