New Cat
    Originally posted by gijjarg
    My cat seems very territorial to new cat. Will it ever work?
    Will what work?
    2013 RC4WD International Team Driver
      Side X Side, would be ideal having a lower CG. Set-up will work.
      "The 40/160 is definitely under-rated at only 160 amps cause I have spiked mine well past the 250 amp mark on 10 cell setups and doubt you will have any issues with it ... I have used the 40/160 on 12 cells with my 3080 powered Apache but that is a lower Amp draw setup." (Punisher67, OSE)
        Sig
        when can I get to see the vid of it running? I see everything is all there already
        My fleets
          right choice
          right choice at all
            Punisher67 has done the codes. The mount will have 7 parts; Front mount, Rear mount, 2 x L-channel F & R base connectors, 2 x frame connectors and a bottom base plate.
              Originally posted by Mel279 View Post
              Sig
              I'll post a link, soon as I take, edit, and upload. Thanks.
                Just a peek at the custom Shulze 2 x 40.160wk mount (a work-in-progress) by Punisher67 .
                  This custom-made mount that accommodates 2 "old-school" Schulze 40.160wk.
                  Many thanks to Punisher 67!
                    I managed to grab a Boat Cover by Proboat. Although, the cover was meant for a huge boat, some alterations and it fits like a glove.
                    Many Thanks to Good Ole' Ken of RCS!
                      The Custom ESC Mount now in-bound. Here's some pics showing the precise fit of the lower ESC mount for the lowest CG, as well.
                      Kudos to Punisher67 -- Awesome Work!
                        U might want to consider putting a metal plate between the two ESC. If one goes up in flames, at least it will not affect the other. Having both up in flames will really make u
                          The clearance between the capacitors of the top and bottom ESC will be very tight. Doubt if a metal plate will fit, maybe a thin aluminum sheet if it can as a "fire-wall". Thanks.
                            Its always better to be safe than sorry.
                              I agree -- a pinch more of safety awareness/precaution could have saved many from total disaster.
                                I got this ESC mount in the mailbox. The mount holds 2 x Schulze 40.160WK SAW Monster and mounts into the HPR C5009 Mystic, Perfect!
                                Compact yet sturdy, nice and clean! Many thanks to Punisher67.
