Connect the servos to the flight controller and Rx. Installation of FBL head, ripped off from my TT X50E FBL. All electronics will be from my TT X50E cos it crashed and no one had the spare parts for its tail end bevel gear so it now sits quietly in the store room.
Century Bell Jet Ranger "Day Dream"
Installation of the tail gearbox with the metal rod drive shaft. First time seeing a metal rod drive shaft. It was missing the set screws to secure the metal rod to the tail so I had to get it from the screw shop. Also greased the bevel gears with lithium grease. The tail drive end is squared and there is a spacer within the tail to fit the metal rod.4 Photos
The motor mount comes with a specific mounting bolt spacing of 30mm apart. It was out of the norm. All my Scorpion motors for 600 size are 25mm. Need to google search for a suitable one from *****ood. Its meant for Trex 600, 550kv and 12S. No choice but to go with it. Then this motor shaft is 6mm dia and the pinion from the conversion kit was 5mm dia. Alamak!!!Lucky me, I contacted an old pal from my flying days, SGtooling and he willingly helped me to drill thru the pinion to 6mm to fit the motor shaft.
3 Photos
