Originally posted by alex_bong
View Post
Century Bell Jet Ranger "Day Dream"
Finishing up the fuselage with securing the tail cover, epoxy the exhausts and windscreens.3 Photos
- 1 like
Leave a comment:
1 Photo
Leave a comment:
Dremel off the forward securing holes of the tail gearbox for it to fit into the fuselage.4 Photos
Leave a comment:
Installation of side supports between the frame and fuselage.4 Photos
Leave a comment:
Time to start work on the fuselage. Installation of horizontal stabilisers.
6 Photos
Leave a comment:
It's alive and flying!!! Just need to adjust blade tracking and tune to 1800rpm.
https://youtu.be/oPHYNZ1-gu4
3 Photos
Leave a comment:
Installation of motor and ESC into the frame. Powered it up and test run them and all is good. Now need to make some landing skids for the frame to test fly, setup the flight controller, ESC and buy the damn CAAS sticker.3 Photos
Leave a comment:
Used back my CC 80HV esc and BEC that used to power my TT X50E.2 Photos
Leave a comment:
The motor mount comes with a specific mounting bolt spacing of 30mm apart. It was out of the norm. All my Scorpion motors for 600 size are 25mm. Need to google search for a suitable one from *****ood. Its meant for Trex 600, 550kv and 12S. No choice but to go with it. Then this motor shaft is 6mm dia and the pinion from the conversion kit was 5mm dia. Alamak!!!Lucky me, I contacted an old pal from my flying days, SGtooling and he willingly helped me to drill thru the pinion to 6mm to fit the motor shaft.
3 Photos
Leave a comment:
Connect the tail to the body, it was pretty straight forward. However there was no screw to pin the tail boom so I had to drill a hole and DIY. Connecting the tail control rod with the plastic connector was a big pain in the rear end.3 Photos
Leave a comment:
Leave a comment:
