Speeder building a Tarot T-2D Brushless Gimbal (ala Zenmuse H3 2D). Quite small. Stay tuned for flight and gimbal test
SGDRIFters Drift Into Quad
wow! thanks for the picture. it gave me an idea how to easily build a martinez gimbal.
i cant find L6234 on local store (even on RS / Element14. Only in ebay). now i can pro'ly start to diy a martinez.
why did it not crossed my mind earlier. geeez. must be get'in old already....
maybe ill start on a single axis with an atmel-based ESC, replace with high amp mosfet (from my bin), replace the chip with atmega328P, and flashed it martinez fw.....hmmmmm..
Originally posted by quaDrobot View Postwow! thanks for the picture. it gave me an idea how to easily build a martinez gimbal.
fw.....hmmmmm..
So here's the video of the flight test using the Tarot 2D brushless gimbal mounted on a hexa. Pls note that there's no post stabilisation done to the video....I merely cut and stitch all footages together.
Tarot Gimbal is build totally stock - no damper or rubber ball swap.
Looks pretty promising for something right out of the box....with wee bit of vibes (if you can spot it) and no visible jello. I'm quite sure with a little tuning, video will be rock solid.
And look at the size!!!....quite similar to the DJI Zenmuse
i didn't get it from foxtech.. got it from oomodel.com http://www.oomodel.com/gopro-brushle...u-p-65534.html
i ran the gimbal without running through the software... it just works... but realize the roll was off the horizon.. so i went to the software and adjusted the initial roll and tilt setting...
now it is running perfect... happy with the purchase...
Originally posted by icube View Posti didn't get it from foxtech.. got it from oomodel.com http://www.oomodel.com/gopro-brushle...u-p-65534.html
Hello everyone,
I've just returned to RC scene and gotten myself a DJI F450 with stick motors and ESCs. I'm also using a Naza M Lite. Tx is a DX6i with AR6210 Rx. I've binded the Tx and Rx.
I am unable to arm my motors. All I get is a start up tone, then the VU flashes green for a few times then a constant yellow flash.
When I connect one of the ESCs directly into the Rx, and connect the batt, I hear 2 start up tones at the same time and the motor responds to input.
Is this enough to tell me what my problem is?
Thank you for any help you can give.I can haz diving?
