need mod help on my EP Apro boat
    Just get foam from anywhere and put it in the hull.
    MS - Mas Selemat
    Looks like u never read the news.
    http://www.straitstimes.com/Breaking...ry_374471.html
    Injet foam or styrofoam? Ms I know but I prefer mj black to white lol.
    Mugen Mrx2, HW 4274, HW Xerun150esc 6s
    SCRT, HW Sct motor, HW Xerun120esc 2s
    Team Driver for HobbyWing, Acorn racing & ManiacRC
      hi,
      1st
      can i mount the heatsink on the esc like this? i need to heatstrink it?
      2nd
      can i mount the esc above the motor as i prefer the CG to be mid or abit forward to the hull.
      3rd
      can i mount the batt sideways as if parallel the boat will roll sideway
      thx alot
        Originally posted by superek4 View Post
        hi,
        1st
        2nd
        3rd
        thx alot
        As long as it works, should be no problem.
        The term should be perpendicular.
          Sure thx
            can i place this way? will the rear of the boat be too heavy?
            how do i cool my esc all the tubes has been use up? can i use a adapter? is there one u guys use?
            usually do u guys set the esc soft , normal or very soft start for boat?
            n whats Governor mode?
            what kind of timing u guys set for medusa motor? low, middel or high?
            do u have a pix how do i put the thrust bearing for the motor?
              U can place it any way u like, just make sure the CG is 33% from transom.
              U can go to aquarium shop and get air tube for 20cents or 30 cents a meter. They sell different connectors there also.
              Soft start will do.
              Governor is for heli use only.
              Medusa is a 4 pole motor, use low timing.
              Picture attached of mine.
              See my reply in red.
                thx alot, I appre it.
                Btw do u guys build flood chamber for ur boat? I was told by Jan at Rc group to build one but it looks difficult.
                Wo the chamber the boat shld b ready by this week testing at bishan park
                  Just 1 quick question. I need to water cool my esc I can tap on any of my existing water tubes?
                    hi, i hv fixed some new tubes on the esc but it seems that the tube is abit too soft izzit ok?
                    will the tube be too soft for the water pressure?
                    n i only hv one pickup point
                      There should not be kinks in ur water tubes. Make them longer. Otherwise get those more expensive fuel tubings.
                      U can run the cooling from water pickup -> motor -> ESC -> water outlet.
                        Do u guys build flood chamber?
                          For me, I dont.
                            Sorry can I run from water pickup->esc->motor plate->motor->water outlet?
                              No problem lah. U are running the boat for few mins only. Which ever direction also can.
                              No water cooling but fan cooling also can.
                                Lol u r a funny guy. I owe this hobby to u, without I would hv sold d boat away.
                                My wife was asking y I m so keen in d boat now which I left 1yr ago.
                                Then I show her ur avast big boobs she fully understand lol.
                                I m going to order some stuffs from hobby city which motor there is better than feigao 7xl?
                                Btw where on earth can I find a bag for my cheapo boat I search d net only found Austria it's us176 I can use d plane wing bag?
