hi bro how is charger turnigy accu cell-6 ? 50 w 5a want to play T-rex 500 . this it good ? thank you for your advice .
hi turnigy acccel cell -6
Originally posted by syboat View Posthi bro how is charger turnigy accu cell-6 ? 50 w 5a want to play T-rex 500 . this it good ? thank you for your advice .
issues been spot so far is the button and fan. heard the button need some pressing to season. and fan get noiser with usage.
so far mine still ok.sigpic
Helis:
Heli 1: Trex 450SE V1
Status: Fit
Date of Operation: 27 JULY 08
Specs: JGF 450TH + RCE-BL25G + GY401 + HS-65HB cyclics + HS81 tail
Radio: Optic 6 + Electron6
Batt: Zippy-H 3s 2200mah 20C
Originally posted by syboat View Posthi how about Power Supply for Chargers 16A 14v DC from hobbycity us39.99 this is to expansive ? is there any place i can buy ?sigpic
Helis:
Status: Fit
Originally posted by syboat View Posthi ok bro thank you .. for your helpsigpic
Helis:
Status: Fit
Not too good experience
My unit start giving me problem after 3 months, In the balance charge mode the second cell voltage keep indicating 0.3V higher than it should be and thus the battery never get charge correctly and the second cell then to be lower voltage than the rest.
Have posted it on hobbycity forum and some have message to me that they have the same problem at different voltage (0.1V - 0.4V) error. There is not way to correct this as you can only calibrate the total voltage which does not help as it still cause the charger to balance the lipo wrongly for the 2 cell. if the problem is on the 4 to 6 cell I would still be able to use it for smaller cell count but on the second cell.
I am presently using a external balancer with it and using it for other types of battery.
Originally posted by nightshade View PostMy unit start giving me problem after 3 months, In the balance charge mode the second cell voltage keep indicating 0.3V higher than it should be and thus the battery never get charge correctly and the second cell then to be lower voltage than the rest.
I just balance them with a Hyperion charger offline till they are 0.1-0.2 +/- than charge directly through deans. The batts never differed more than 0.1-0.2v even after 10 cycles but I still balance them offline for kiasu sake.Practice makes permanent. Perfect practice makes perfect.
Originally posted by protyne View PostBro I got similar issues with my 2 units of B5. Seems that such economical chargers have their limitations.
They're totally different chargers ! ...the Imax dun even come close to the accucel 6.
Granted, it's no high end charger like a Bantam or ICharger, but it gets the job done. There are limitations, but for the price, you'll learn to live with it.
I believe nightshade got a faulty unit as I know many bros here got the Accucel 6 and they dun have any problems with it's balancing function.Seriously running out of ...Storage space !
aha, i've experinced those balance issue, its not the charger, it da batt goin bad. took very long time to balance n still unbalanced (till safety timer triggers), new batts no prob (not all), even charged 3 in parallel...Current BlinkĀ²:
Trex-600N: TTRL53H/H#523/CarbSmart/CYATGv3-Gview/JR770T
Beam-E4: SC-8/13T/SC-55A/LT2100T
History BlinkĀ²:
Belt-CP
Walkera-#60
"Every takeoff is optional. Every landing is mandatory."
Nate Waddoups
Originally posted by Ghostfit View PostBro, I'm assuming you're refering to the Imax B5.
Just received my Acc-6 yesterday. The look, feel and even the OS feels so similar to B5. Wondering if they were from the same factory.
Will try the balance charge function soon.Practice makes permanent. Perfect practice makes perfect.
