thanks....
i would want to get as a kit wif electronics....or rtf....
it would be confusing and wasting $$$ if i buy kits and the electronics seperately...
Walkera 36
stock plastic rotor head & tail
stock G011 gyro
Hobbywing 40a esc
Walkera 3800kv brushless motor
Walkera servos - aileron & elevator
Tower pro - pitch & tail
FG 288mm blades Walkera 35c
no electronics & main rotor hub
'in the store'
thanks....
If it is confusing and wasting $$$ to you, you still have quite a fair bit to absorb and learn actually. To us the more seasoned flyer, you are actually saving money buying the right stuff the first time round be it separate or together.
I agree with johndyl, packaged ones are usually not quite there.
so johndyl is trying to tell me that package ones are not that gd..
and its better to get it seperately....okayy..
then how about the assembly..,..is it better to assemble the heli ourself than assembled..??.
but then do you have any suggestions bout the comet 500..??.
my minds still on it...
Walkera 36
stock G011 gyro
Hobbywing 40a esc
'in the store'
It is always preferred if you can self assemble - from there you can learn more about the machine.
Of course, it is more common nowadays that the heli kit comes partially assembled, with only the main shaft (with rotor head), frame and tail left to put together.
Either way is fine but like what Johndyl and Edmond mentioned, spending less than doesn't save you more - you'll end up having to pay more for a better radio, servos, gyro, motor, ESC you might as well just get them separately.
Moreover your considerations should also cover availability of parts locally as you're new, crashing is quite the norm.
even if it comes assembled u shld always take it apart to check, locktite all metal parts while u r at it
I agree with you kekeke but I dun practise it or rather partially. I scrutinised it, pick a few to loctite there and here kekeke.
I guess experience do count lol. I will usually fly a new heli easy for the first few flights, land very frequently with a few tools and I usually get the few usual suspect that requires tightening down. Of course, I still experience the odd screws that will go missing entirely.
Top of the stuff I lose:
Screw for frame (usually 1 or 2 at most)
Screw for Header Tank (tangles like a mad doll)
Screw for boom brace (tangles like a mad doll)
Screw for Glow extension (tangles like a mad doll)
Screw for Canopy
Must check list:
Whole Rotor head, all ball links
All control mechanics and ball links
Engine/motor mount sitting gear meshing shaft guide whatever, all stuff moving, better check at least once.
thanks for the info...
and i strongly agree wif wat Ivan M says...
the electronics in rtf package are not that gd...and are low quality....
my 35c...was bought as a rtf package and the esc and servo were easily jammed...the gyro was also not that stable during flight...then now, the transmitter is spoilt...ohh man...
i've bought spares, and some other upgrades for nothin...
i've wasted $$1000 plus....
should get a gd heli....
now that i know...thanks...
alrite...my next question...
the trex 450 s/cde...how its performance.??..is it gd..???
Walkera 36
stock G011 gyro
Hobbywing 40a esc
'in the store'
all helis comes the same without proper electronics
i think you better tell us your budget
and your current status like battery, charger and esc.........etc
its improtant to serach a better value for your rc future
