comet 500 v2
    comet 500 v2
    hello everyone ,
    i'm newbie here currently having walkera 35c..
    but i'm no longer using it due to several crashes i've made., i had notice from RC-Expert.com...and i'm lookin forward onto comet 500 v2...
    does anyone here had this heli..??
    need to know whether this heli would be good for beginner...
    i really need this info can anybody help..??
    zakir
    Walkera 36
    stock plastic rotor head & tail
    stock G011 gyro
    Hobbywing 40a esc
    Walkera 3800kv brushless motor
    Walkera servos - aileron & elevator
    Tower pro - pitch & tail
    FG 288mm blades
    Walkera 35c
    no electronics & main rotor hub
    'in the store'
    i have seen here in china
    not a good heli
    the heli using 450 power system and its just a little bigger than the 450
    they design in such way that you can use 450 spares on a bigger heli
    but they forget about the size
    all spares on 450 can be use except the tail boom, belt and of course the body..
    its better you could check the spares availability in singapore
    beware of chxxxxxx hxxxx
      thanks for the info....
      wat 500 size bird would u recommend for beginner like me...??
      How about raptor e550 or e620..are they good...??
      Walkera 36
      stock G011 gyro
      Hobbywing 40a esc
      FG 288mm blades
      Walkera 35c
      'in the store'
        How abt a lama?
          i may think a raptor e series are good all because of the available of spares..
          btw y 500 class you looking for?????
          hirobo lama is diffcult to get spares even shs is bringing them in
          their spares are also a little higher than the raptor
            im lokin for 500 size bird coz from wat i know the bigger the heli the better it hover...
            i dun really know wat to get..??from other threads...they said that mini titan is good heli for both beginner and 3d...
            i need more info...
            Walkera 36
            stock G011 gyro
            Hobbywing 40a esc
            FG 288mm blades
            Walkera 35c
            'in the store'
              ive tried lama....i could hover it alrdy...so now i wan to learn new skill and get to intermidiate level...
              Walkera 36
              stock G011 gyro
              Hobbywing 40a esc
              FG 288mm blades
              Walkera 35c
              'in the store'
                i need more info...
                the mint t or trex 450se/v2 is gd..u can set it up to be v stable then setup for agility again when u r ready
                for 500 sized.. the trex 500 and the msh protos should be gd options..u 'll have added stability.. but it is not as convenient as a 450, so u'll probably end up not flying it on a daily basis.
                450 sized helis are great for quickies.. and gd for squeezing in flights during lunch breaks or weekdays after work. helps u improve alot faster too
                For sale
                  thanks for the info johndyl....
                  so u r saying that the mini T and trex 450 se/v2 is gd and very stable.....and the bird flies the same performance as trex 500...
                  and if were to take mini T...i have to upgrade the parts to a better one in order to get into 3d....
                  does that also happens to trex 450..???
                  Walkera 36
                  stock G011 gyro
                  Hobbywing 40a esc
                  FG 288mm blades
                  Walkera 35c
                  'in the store'
                    The , main problem with the Mini-Titan would be the tracking issue after crashes . Seems to be , the hole in the main rotor hub "ovals" Causing the thing to tilt and causes the problem . So , just get the metal hub and you are good to go
                    Helis
                    Logo 500 3D
                      ah... i dont think any 450 sized will ever be as stable as a 500. but it is stable enough if u setup well..
                      flybar wts will help too until you r ready for acrobatics
                      i'll advise getting a trex 450se or sev2 or copterxV2(99.99999 trex clone). nothing to upgrade. parts are everywhere
                      like what helifanatic and some others said, the stock MT will have some probs after a while.. and their blade grips are non standard which can cause tracking problems(this is true even with full metal heads)
                      For sale
                        okayy then i will go for trex 450.....
                        btw copterX got sell in sg anot...??...
                        seen it at u.s retail shop...its blue cnc parts everywhere...coool...
                        Walkera 36
                        stock G011 gyro
                        Hobbywing 40a esc
                        FG 288mm blades
                        Walkera 35c
                        'in the store'
                          copterx.. i think have locally.. but not too sure... if not order in lor
                          parts wise, u can use align's if u cant find copterx ones
                          For sale
                            btw, there are many many preloved align trex450's in the market place.. some fully setup..
                            go for the se or sev2 ones, or at least a cde mod to direct servo linkage
                            have a browse and pm some sellers, u may find a bargain
                            For sale
                              thanks johndyl...
                              i will aim for trex 450 then...
                              just to be sure...which one should i get....the cf or alloy ones...??or others...??
                              Walkera 36
                              stock G011 gyro
                              Hobbywing 40a esc
                              FG 288mm blades
                              Walkera 35c
                              'in the store'
