Originally posted by wilson76
Discussion/Review on Trex600n issue
Lastest upgrade! Align CF Paddle of similar design as V-blade.
Metal Tail slider
2in1 Regulator B6T from Align w glow starter & 2S lipo (130g)
Setup
Segar Field@20th Dec - After engine overhaul & electronics upgrade! Not forgetting the Red Tail boom too...Trex600 Nitro
OS50 Hyper
B6T 2In1 Regulator
Zimmerman
Rev Max
DX7-AR7000
GY401+9254
S9351
Originally posted by wilson76Yup.. Sunday i should be able to fly. And i am using rev max! So far so good!
Metal Tail slider
Setup
Originally posted by wacsHi there, I just got a TREX 600N, looking at electronics options now, what are the advantages and disadvantages between the rev max, throttle jockey pro. Also how do these products compare with the GV-1?
Maybe can check with rest.Trex600 Nitro
OS50 Hyper
B6T 2In1 Regulator
Zimmerman
Rev Max
DX7-AR7000
GY401+9254
S9351
I've used the GV1.
Nice robust piece of technology.
But, like most would say, it's old tech.
The Gv1 wouldnt respond as fast as the later gov such as TJ pro,or the throttle limiter Revmax.
Thanx!SLOPE SOARING NOT A CRIME
Situation:
For past 2 flight, encounter my engine seems to be throttling up & down slightly while in flight. From observation, notice the tail will twitch too and engine's sound also change up & down.
Troubleshoot:
With that, I suspect my Rev Max might be the culprit as the throttle servo can be seen to be moving by itself while in a hover without any loading.
Thus i off my rev max in flight and ah... Problem solved.. It stops twitching and throttle back to normal.
Decide to check the wiring of the rev max and Discovered that the sensor cable was somehow being 'cut' slightly exposing the wires inside. Highly suspect that the insulation of the cable got cramped at the edge of my carbon frame as the 'cut' was exactly at the edge. So conclusion, under prolonged vibration by the heli might cause this 'cut' resulting in glitches.
SO if you guys out there using any Gov or RexMax and encounter such symptoms, do check the cable for any expose wiring resulting in glitches!Trex600 Nitro
OS50 Hyper
B6T 2In1 Regulator
Zimmerman
Rev Max
DX7-AR7000
GY401+9254
S9351
Troubleshoot:
SO if you guys out there using any Gov or RexMax and encounter such symptoms, do check the cable for any expose wiring resulting in glitches!Look on the wife's face when visa bill arrived, Priceless!!!!
It's not just a hobby, it's a lifestyle.
