Originally posted by detach8
Belt CP - Improving the breed
Originally posted by edmond22Bro, the tracking is a pretty weird stuff. Tony was able to track his perfectly on stock setup, We both tried to get mine to do it but was unable to. I switched to carbon blades and it tracked perfectly lol. maybe the trick is to balance the blade properly, still learning that science.
edmon, yea it happens on my plastic head too.. i will get maybe 0.5cm to 1cm off track with half turn on either side because beltcp doesnt have the shorter links that we can turn unlike trex or mini titan, so i can accept that
problem is mine's crazy more than 1 whole inch off track, no matter how many half turns i've made.
no time to drop by punggol let ghostfit see. maybe nxt wk i drop by jet get myself a set of new blade grips to try.
have you tried the carbon blades?
usually blade grips will not cause this problem unless you are mixing metal grip with plastic heads.
I have a tracking problem too and I narrow it down to the feathering shaft that was bent. Never crash it, but somehow it was bent. Also, while flying the belt CP, please take note of wear and tear. once you have flown about 20 packs, check for loose linkage.
Originally posted by detach8edmon, yea it happens on my plastic head too.. i will get maybe 0.5cm to 1cm off track with half turn on either side because beltcp doesnt have the shorter links that we can turn unlike trex or mini titan, so i can accept that
bro, hs55 and the esky servos are abt the same size, they are replacement parts...
as for the frame, they are for the old trexOriginally posted by FoRGotTeNhttp://trextuning.com/heliupframe.php
are you all trying to do something like this or what? O_O
sorry, new, read here read there got qns must ASK!!!For sale
