ok thanks for all your input, what about the gyro? If i can get a esky HL gyro at $80, should I do the upgrade?
Belt CP - Improving the breed
tanlaw: my personal suggestion... don't waste your time on the esky HL gyro. invest in a GY240 at least... or a LGT-2100 from Ken (ammo)
new question: bling head issue
how do you guys install the retaining pin for the center hub? I find it very troublesome to take out / put back in an event you need to replace main shaft. the stock plastic head is easeir (bolt + nut). does anybody have a better alternative / mod to that pin?
i got a ball link that broke with half the screw thread inside the swash, how to take that out man... or is it a goner?
where do you guys buy the bling head ball links? can i use back normal ones? the stock bling balls seems more fragile (soft aluminium)
what are the usual casualties in a crash for a bling head?
I really prefer to use the clamp method ! .....you can apply the force equally and SLOWLY to move the bearing out ! ....lots of time to react in case anything gose wrong.
With the hammer method, everything happens with a thud ! .....and if you Wo Wo king ......easy to end up with swollen fingers and thumb ! (Dun ask me how I know this ! )Seriously running out of ...Storage space !
Originally posted by GhostfitI really prefer to use the clamp method ! .....you can apply the force equally and SLOWLY to move the bearing out ! ....lots of time to react in case anything gose wrong.
With the hammer method, everything happens with a thud ! .....and if you Wo Wo king ......easy to end up with swollen fingers and thumb ! (Dun ask me how I know this ! )For sale
Originally posted by tanlawk guys...another ques was changing my tail boom. the boom can't seemed to be tighten, how come? I screwed back the 4 small screws but the boom can still move if I pull hard enough, pls help
while you're at it might as well apply masking tape to the tail assembly to lock that end too !Seriously running out of ...Storage space !
