like you said, he went to field play basketball.
The Mini Titan Thread
Originally posted by detach8like you said, he went to field play basketball.
Chay, .....so when can I see your Dragonus fly ?Seriously running out of ...Storage space !
you mean masterbedroom huh.
So the jgf 450 is doing well huh, can we actually expect a trex-like characteristics in terms of power?JR PCM 9XII
35.150
BEAM E4
HS65 Cyclic
Futaba S3154 Tail
Scorpion 2221-8
JETI Spin 44A
JR RS 77
Logictech 2100 TL Gyro
Thunder Power TP2070-3SX
A Bottle Of Guts, Neat.
Originally posted by GhostfitBasketball ! ....everytime you go to the field, ...NEBER BRING YOUR HELI one ! .....now yu wanna "jio" me !
hahah.. long story lah.. earlier this week.. crash car.. intercooler gone.. cross member dented.. wallet burn big hole.. den flew my compy300.. crash.. spindle shaft.. main shaft.. tail boom.. main gear.. all gone..
dragonus? still trimming.. swash leveling tool pretty useful.
btw.. remember the cheap cheap cf blades i mentioned.. not bad leh. its balanced..tracking oso good. den again.. could i lucky get one good set.Guys.. I can't do 3D. So if you see me flying inverted, I'm in trouble...
Originally posted by glenn cainwe can assign greenhorn as the crash pilot for mini titan to get statistics tooGuys.. I can't do 3D. So if you see me flying inverted, I'm in trouble...
wah you owe a dragonus and erap ah, is it a 550 or 625? any plans to use a123?
Me still stuck, waiting on the motor and tail servoJR PCM 9XII
35.150
BEAM E4
HS65 Cyclic
Futaba S3154 Tail
Scorpion 2221-8
JETI Spin 44A
JR RS 77
Nicely done up.
Just wondering if there is enough space to put the receiver inside the heli instead of securing it to the side? How about the Gyro, is it mounted inside the fuselage?
Thanks
Originally posted by MiniTitan325Hi, this is my new Mini. I'm very happy flying on this kit. I have change the ball link to align ball and link. For the stock ESC, I add in cooler master heat sink on both side. This is to reduce the heat faster and I have already tested.Heli
Plane
PT-17w : Sold
Buggy
Charger : Tahmazo T15
Balancer : TP205
Originally posted by greenh0rnhahah.. long story lah.. earlier this week.. crash car.. intercooler gone.. cross member dented.. wallet burn big hole.. den flew my compy300.. crash.. spindle shaft.. main shaft.. tail boom.. main gear.. all gone..Seriously running out of ...Storage space !
Originally posted by GhostfitQuick ! Quick ! ....log off and switch your computer off before your computer or harddisk crash ! ......since you're on a roll here !
PC crash nevermind.. office wan.. just book out another set lor
by the way.. settle the dragonus trimming liao.. very stable bird.
can consider leh bro.
mini titan kit ETA in Feb.. can hardly waitGuys.. I can't do 3D. So if you see me flying inverted, I'm in trouble...
Originally posted by greenh0rnPC crash nevermind.. office wan.. just book out another set lor
mini titan kit ETA in Feb.. can hardly waitSeriously running out of ...Storage space !
Originally posted by GhostfitNeber show me your dragonus flying ! ...Gonna run UBEC and governor mode on my E325.
wah liao.. 450 size heli dun need lah.. UBEC and governor lah.... get the hurricane 550? wonder if skyhobbies is getting the upgraded version or the older one.Guys.. I can't do 3D. So if you see me flying inverted, I'm in trouble...
Originally posted by greenh0rnwah liao.. 450 size heli dun need lah.. UBEC and governor lah.... get the hurricane 550? wonder if skyhobbies is getting the upgraded version or the older one.
So far, all the really good 3D flyers I've seen and met are running external BECs and I'm convinced by them, the load when all 4 servos and a gyro are in full operation (Moving) can be quite high and this overpowers the ESC's BEC (Which gets very hot !)
I'll get the 1st eRaptor sized heli which has the killer Aplus/Dragonus "bird of prey" looks ! .....I'm just waitingSeriously running out of ...Storage space !
