The Mini Titan Thread
    Like some people here, I am pending on my preorder for mini titan, and is thrashing around to better understand my motor options. So far, my research (if somewhat shallow) turns up that much of the config are close to trex, 120 teeth main gear, but it is heavier nonetheless at 750g as listed.
    Meanwhile, bumping around, I saw that the JustGoFly 450F looks very much like mini titan stock motor. Check out r*t*r.com.sg and this http://www.trextuning.com/450F.htm, and this too http://runryder.com/helicopter/t2979...ght=mini+titan
    looks similar?
    JR PCM 9XII
    35.150
    BEAM E4
    HS65 Cyclic
    Futaba S3154 Tail
    Scorpion 2221-8
    JETI Spin 44A
    JR RS 77
    Logictech 2100 TL Gyro
    Thunder Power TP2070-3SX
    A Bottle Of Guts, Neat.
    looks similar?
    i have a JGF450TH, CC35, HS-65, GY401, F3154 on standby already
    Guys.. I can't do 3D. So if you see me flying inverted, I'm in trouble...
      wah you shiok lah you. can we really assume it to be close to trex?
      JR PCM 9XII
      35.150
      BEAM E4
      HS65 Cyclic
      Futaba S3154 Tail
      Scorpion 2221-8
      JETI Spin 44A
      JR RS 77
        if cannot.. put back in my trex lor..Gotcha!!!!
          where do you get a f3154? what does it come with? do you think bluebird servos will do on mini titan?
          What is the minimum number of amps for a esc supporting a trex?
          JR PCM 9XII
          35.150
          BEAM E4
          HS65 Cyclic
          Futaba S3154 Tail
          Scorpion 2221-8
          JETI Spin 44A
          JR RS 77
            huh? that's the futaba digital servo (3154).. come with a few horns lor..kekekek as for how much amps for a ESC supporting a trex? dunno leh.
            align do sell the trex with their 25A ESC. i kiasu.. use CC 35A
              Depending on your flying style and motor ....gentle hovering and FFF = 25A ESC can already.
              Wild and scary 3D flying, you'll need at least 30A continous current rating ESC.
                I would suppose the stock esc and motor will be a good starting point to get a very good idea of what kinda range the mini titan's power system requires.
                In fact, i wouldn't be surprised if the stock esc and motor is one of the best performing power setups for the mini titan.
                  so most 3D setup actually do not need 30A esc unless we are having mega motor or some hot ones?
                  JR PCM 9XII
                  35.150
                  BEAM E4
                  HS65 Cyclic
                  Futaba S3154 Tail
                  Scorpion 2221-8
                  JETI Spin 44A
                  JR RS 77
                    It would be better to leave some overheads in terms of current limits if using for 3D, burst currents can peak pretty high at times.
                    But generally speaking, for helis of the mini titan, trex 450 size, 30amps will be a good guideline.
                      ah, the man with the stock speaks. how the order coming?
                      I guess I could use my 30A apache first. what about bluebird servos? anyone have experience with them? is rotor holding the f3154?
                      JR PCM 9XII
                      35.150
                      BEAM E4
                      HS65 Cyclic
                      Futaba S3154 Tail
                      Scorpion 2221-8
                      JETI Spin 44A
                      JR RS 77
                        Rotors was loaded with them for just a few days before the arf + motor & esc version were wiped out.
                        anyone got anything interesting to report?
                        JR PCM 9XII
                        35.150
                        BEAM E4
                        HS65 Cyclic
                        Futaba S3154 Tail
                        Scorpion 2221-8
                        JETI Spin 44A
                        JR RS 77
                          why not a JGF 500th for the motor? Its the biggest from the JGF series for now.
                          My Hangar:
                          (SE-maiden 15/03/06)
                          (XL-maiden 16/10/05)
                          Heli 2:RAPTOR 50 TITAN
                          (TITAN-maiden 16/06/2006)
                          Heli 4:Flasher 250
                          (maiden 13/09/2010)
                          Transmitter:
                          JR 9XII(XPS 2.4)
                            Sorry, only manage to get a ARF heli only version so cannot comment on the motor and ESC.
                            Initial 'out of the box' impressions
                            1) Tail Boom is 14mm instead of the usual 12mm as in Trex types and copies.
                            (Nice to see Daiso run out of 14mm tubes instead of the 12mm ones for a change)
                            2) Blade holders are like 6mm grips, so you'll need lots of spacer if you're intending to run Align's blade here.
                            3) Lots of parts molded as 1 piece item, the main frame is a work of art and I'm still trying to figure out how they manage to mold it as 1 piece with all the details. The landing skids are also 1 piece, you'll either like them or hate them.
                            4) Lovely owner's manual ! ....written in proper English and not a translated Chinese job.
                            5) Got the BEST tail rotor Mechanism of any micro heli I've ever seen ! .....super duper smooth !
                              good to hear them.
                              i wonder if jgf 500 could do well with 4s a123 M1 batteries...or even emoli?
                              anyone heard of these z-power z10a-3300? google sourced nothing, which ggoodrum in rcgroups are using them with 4s a123.
                              interesting stuff these days
                              JR PCM 9XII
                              35.150
                              BEAM E4
                              HS65 Cyclic
                              Futaba S3154 Tail
                              Scorpion 2221-8
                              JETI Spin 44A
                              JR RS 77
