Oh I forgot to ask you, are you running 8s using T-180 esc?you might wanna consider getting hv esc instead. T-180 can handle up to 6s only bro. Bro post the build here for both of your projects, this should be interesting
37" catarmaran twin bulit and Miss geico conversion
Originally posted by Mel279 View PostOh I forgot to ask you, are you running 8s using T-180 esc?you might wanna consider getting hv esc instead. T-180 can handle up to 6s only bro. Bro post the build here for both of your projects, this should be interesting
i be running 2 T180, 2 T600, twin stingers and 2 flex cable/wire drives.Warpath Wong
Originally posted by Battle fury View PostHi Mel,
i be running 2 T180, 2 T600, twin stingers and 2 flex cable/wire drives.My fleets
Originally posted by Mel279 View Postso you'll be running 4s each side is it?if so,forget the 442 prop, go for 50/3 prop instead. I think it can handle bigger prop unless your running 6s.Warpath Wong
Originally posted by Battle fury View PostYes 4s each side .i am a conservative guy i like to start with smaller props check temps everything ok then i work my way up. Same goes to my liposMy fleets
the rudder look like this or maybe it is this.
http://hopf-tenshock.de/shop/article...26aid%3D517%26Warpath Wong
My experience with twin setup, the boat prefers higher rpm rather than bigger prop. I am running 1800kv motor with 4S and X442 props in my 30" Cat. Initial torque is good but top speed is no good. I ran on 5S and wooohoooo. Thatz more like it.
The starboard side esc just stopped working three weeks ago. I suspect it is caused by the motor, cos I tried to run the motor with another esc, the esc went hot and motor wont run. So now will change out both motor and esc.
For ur motor, I recommend run on 6S with the X442 props. U will love the speed.
