Whoopee..! finishing laying some CF on daytona cat power plant
37" catarmaran twin bulit and Miss geico conversion
its a CF 37" daytona cat can be bought here www.fightercatracing.com .Ben the man good quality serviceWarpath Wong
Thanks mine is just a small small project, i wanted to prove to myself that without spending much you can rocket this cat over 100km/h. So this a budget bulit
i love cats, you should look out for hydrolift 1200 coming out at May or HPR if u r really hardcore. its a real beauty
leopard 4074 -2200kv and 4082- 1500kv.Warpath Wong
Originally posted by Battle fury View PostThanks mine is just a small small project, i wanted to prove to myself that without spending much you can rocket this cat over 100km/h. So this a budget bulit
leopard 4074 -2200kv and 4082- 1500kv.My fleets
bro
this guy mystic 114 using 2 4082 2200kv 6s
http://www.youtube.com/watch?v=yXMgZ..._order&list=ULMy fleets
Originally posted by Mel279 View PostIs hydrolift came from Korea?I only have H&M drifter M twin drive at the moment which is the same size as your fightercat. I was thinking of getting a mystic M or hpr135 someday. So are running the cat with 2 T600 1400kv motors?what size of props are you going to use?
Yes i be running twin t600 1400kv. They are really good value for $$Warpath Wong
Originally posted by Mel279 View Post8s?wouldn't u try smaller prop first...like x442?anyway, are you using a wire drive from Fightercat?I was so surprise with the leopard motor that can handle 6s using 2200kv with ease from the video I've show you. Im guessing its running 80+mph, just a guess
Yes as a matter of fact i will start of with 442 then i work my way up to 50mm prop. Thanks for the tip MEL
I be using 0.187 flex cables. Then maybe a switch to wire drives later. U might want to consider this paint job when you have ur HPR. wicked sick!
JBS 2010/11
Warpath Wong
