Any downside if using 3s packs in series
    Hi everyone
    I was looking a batt prices. Running 2 3s packs appears cheaper for the same capacity than one 6s batt.
    I was wondering if there are any downsides to using batts in series. Apart from less flight time.
    Hope to get your advice
    Thanks Ken
    3s+3s works the same as 6s.
    Flight time is the same.
    The two packs will need to be similar.
      Thanks
        Downside = extra connectors
        Esky Dauphin
        Walkera Lama 2
        Walkera 5G6
        Brushless Micro-T
          Downside, mismatch between packs1 and pack2. The weaker packs during usage will be the first to die after some use.
          That is why a 6cells pack is more expensive than individual 2 set of 3s lipo packs .
          The 6 cells are carefully balance and matched during manufacturing process.
            Thanks guys
