Balancer wire broken
    Yikes, I'm charging it with an old non-balanced charger now. Any way to salvage this? Thanks!
    u'll have to cut open the pack to solder it back..
    be careful though..
    For sale
      Hmm don't think I'll want to risk that given my poor soldering skills :P Looks like I'll have to just charge this without balancing and maybe use it for a few more cycles before saying bye bye to it
        FYI : http://www.daddyhobby.com/forum/showthread.php?t=18312
        Search function is pretty useful.
          Since yours is only the black wire broken, u'll just have to connect it to the main black wire (by cutting up a small piece of isulation from it to expose the cores to be soldered to). Don't have to open up the pack.
          Fixed-Wing
          GWS Zero
          Fliton Extra 260
          Hacker SuperZoom 4D
          Thunder Tiger Velocity
          Scratchbuilt Depron Profile Extra 300
          Thunder Tiger SuperCub (RIP - Resting In Pieces)
          Scratchbuilt Lama Plane
          RICCS Mirage 2000 #1 (RIP)
          RICCS Mirage 2000 #2
          Rotorcraft
          Thunder Tiger Mini-T
          Esky HBK2
          Esky Lama V4 w/SuperShaft
          Radio
          JR-9XPS
            great idea
            For sale
              Thanks for the tip Adrian.
              Wow xeqouz so I can actually solder the broken part to the black wire permanently, and it will have no impact when I fly or charge? This sounds like the best solution!
                I'd been doing that for a few lipos. Unless the wires are mixed up at the factory(which I encountered once! Found that out when I had problem checking the batt voltage with e batt checker, dunno wat may happen if I plug in to the charger), otherwise the small & big Blacks are common, likewise for the Reds. For the middle wires, the lipo gotta be opened up at least partially to repair..
                  Yep.
                  Fixed-Wing
                  GWS Zero
                  Fliton Extra 260
                  Hacker SuperZoom 4D
                  Rotorcraft
                  Esky HBK2
                  Radio
                  JR-9XPS
                    Thanks you sirs. This bugger still has some life left in him
                      Ya lar, get the Orange type of Lipo then you wont have the problem mah
                        Ya. The black type one should not have this prob..
                        Fixed-Wing
                        GWS Zero
                        Fliton Extra 260
                        Hacker SuperZoom 4D
                        Rotorcraft
                        Esky HBK2
                        Radio
                        JR-9XPS
