Originally posted by MacDream
View Post
Gws P-38 Lightning
i sliced alot of foam from the place your esc pic is. if it;s small enough, you can stuff it in the cavity. if not, slice a long channel to the face of the boom, that should solve your cooling and esc problem, you can refer to my pics, i think i did show where the escs are mountedDUCT DUCT DUCT GO!!!!
I've decided to enlarge the cavity to accommodate the ESCs. So far, it looks ok. Also cut elevator servos slot. . . silly me, forgot that Y-cable rotate servos is reverse directions. Ended up having to re-cut one of the holes. . . which brings me to wonder, if we use y-cable for motor/ESC, what effect will that have on motors? Does it have reverse effect on one of the motor too??
Originally posted by MacDream View PostI've decided to enlarge the cavity to accommodate the ESCs. So far, it looks ok. Also cut elevator servos slot. . . silly me, forgot that Y-cable rotate servos is reverse directions. Ended up having to re-cut one of the holes. . . which brings me to wonder, if we use y-cable for motor/ESC, what effect will that have on motors? Does it have reverse effect on one of the motor too??
a y-cable only connects in parallel. For the reversing effect, you a need a y-cable with an inverter.
as to the effects of ecs/motor on a y-cable, basically, you can control two motors with one channel. It frees up one more channel on your receiver (can use as gear,flaps, or even machine gun )
however, the dis-advantage is if your twin motor and esc combos are not of the same health. (date of purchase, condition, length of use), your motors will not be in syncronization, which is bad for your plane. And using a y-cable prevents you from triming the engines to sync.
personally, i prefer having two channels to two motors. It;s safer.DUCT DUCT DUCT GO!!!!
Originally posted by tboltsg View PostHi fellows,
Finished painting my P-38, maiden it as a white ghost of a plane before painting about 1 or 2 month ago.
Just to share a couple of pics.
Beautiful plane on the ground and in the air- have fun.
tboltDUCT DUCT DUCT GO!!!!
tbolt
cheers
tbolt
How did you get the nose art?? Can share??
Originally posted by TomcatFLYER View PostOKAY, actually, the y-cable doesn't reverse anything. the reason why your servos seem reversed is because of the orientation of the servo. Try connecting two servos to a y-cable and have both servos with the horn-face side (the side where you screw in) facing you. you will notice the servo moves in the same direction.
Machine guns... hmmm... what's your idea??
Originally posted by MacDream View PostWell.. I've got 2 identical motors and ESCs. They are both brand new.. I plan to employ them in push-pull fashion. Starboard engine normal, Port engine reverse.. hopefully that will reduce the effect on non-sync engine.. or it will be a really short maiden.
regardin your propellers, don't use identical and reverse one. get counter-rotating propellers. i will pm you how to get themDUCT DUCT DUCT GO!!!!
Hi fellows,
Thanks for the all the comments. U guys r a nice bunch. The nose art is a pic I found by wandering the I.net. Just print out and scotch taped onto the plane. The words are hand painted.
Please make a stand to rest your P38. Sit mine for a couple of weeks and it developed flat tyre on the rear. Pops back to shape after I made a stand to rest the aircraft.
Attached close up of the nose art, will attached the pic file of the girl when i find her in the jungle of computer files.
tbolt
