Selling a brand NEW in box LOGO 550 SX KIT Heli at S$700. Deal at Simei area or Simei MRT. PM me if u are interest in buying.
Low baller stay away from my selling thread.
LOGO 550 SX is the next step in the LOGO 500 Series. The 550 LOGO SX keeps all the proven and popular components of the LOGO 500, while incorporating several new developments to sustain today’s technical requirements during extreme flight manoeuvers.
- 550mm main blades
- 6 S Lipo mit 4500-5000 mAh, - Alu-rotor head yoke with 8mm spindle shaft
- light und durable chassis fiberglass reinforced frame - direct servo link to the swashplate
- Hollow main shaft with 10mm diameter
- Herringbone main gear with 153 teeth (module 07)
- Motor counterbearing with additional main shaft support
- colored fin set in neon red, matched with the canopy
- Extra-strong 22mm diameter tail boom
- Detailed airbrush canopy in neon red
* Note: counter bearing is for a motor with a 5mm shaft and 30mm spacing for mounting
Specifications Helicopter
Rotor diameter 1245 mm
Rotor blades 550mm
RTF weight 2950 g
recommended batterie 6S 5000 mAh LiPo
Main gear ratio 9,56 - 12,75
Main Gear size 153 teeth Modul 07
batterie slot 62 x 54 x 300 mm (HxWxL)
Length 1070 mm
Hight 360 mm
Width 210 mm
Kit Content
Kit Kit with VBar Rotor Head
Accessories Motor counterbearing with mainshaft support
Manual detailed printed manual
Motors ---
Motor pinion ---
ESC ---
Servos ---
VBar electronic ---
Blades EDGE 553mm FBL
Tail Blades EDGE 92mm
Canopy Airbrushed Canopy
- 550mm main blades
Rotor blades 550mm
RTF weight 2950 g
Length 1070 mm
Hight 360 mm
Width 210 mm
Kit Content
Motors ---
Motor pinion ---
ESC ---
Servos ---
VBar electronic ---
