Thanks, I'll check it out.
500size Airwolf
Hi Guys, just sharing my first heli fuse scratchbuilt fuse...made from foamboard...
ATOM 500
Spektrum DX7 w/ AR7000 Rx
Hobbywing Platinum 60A ESC w/ Stock Motor, GY401 w/ Align DS620
3x Align DS520, 425 stock CF Blades
TREX 450XL HDE (sold)
Aerofly Pro Deluxe Sim
@ perfect1...here is the pic of how the build started...
the base frame were first drawn in autocad to get the dimensions. I had to overlay the airwolf fuse drawing to get the right size of the fuse for it to fit in the atom500 frame.ATOM 500
Originally posted by Super-Hornet View PostReally nice.. That must be very light fuselage u got there
Are u going to harden the structure?
SHATOM 500
Slammer dude, you are a genius! Foam...incredible! I am just a lil worried about the fuselage coming apart during flight but I am sure you would have got that aspect all figured out. Do post a vid or some pics during the maiden.Heli-ADDICTION:
thanks a bunch feudallordcult...no worries about it coming apart, im more concerned about the tail not yawing on one side knowing how wide the vert stab is, but ill be checking on that on the maiden and might do a little mod afterwards...cheersATOM 500
The most important area that require rigid (IMHO), is the location that hold the main shaft to the fuselage.
Again, IMHO, if your main shaft can move around (or stir around) inside the fuselage, when u spin the rotor blade up, and together with "wheels" based heli, the heli might goes into a "ground resonance"... meaning the heli will shake itself violently and if the resonance become severe, the heli/fuselage might break apart.
So, when u spin up your heli for the first time, do take care to see whether will it goes into ground resonance or not.
SH
Originally posted by Super-Hornet View PostThe most important area that require rigid (IMHO), is the location that hold the main shaft to the fuselage.
SHATOM 500
