Setting Digital Trim for Firing?
    Hi
    Is there a quick way to set the digital trim to the lowest pt for firing (either main gun or machine gun) on the Tamiya tank? I use the Futaba 10CAP.
    As you all may know, the analog TX can adjust trim in a single swoop. But I find myself struggling in trimming down using the digital Trims. I have nevetheless adjust my trim to jump at bigger steps though! (so it's faster now, but NOT fast enough!!!)
    Is the someone to get aroung this problem? Eg, using a conditional mixing? if so How?
    Pls help
    use EPA and DR ????
    At least this hobby lets you know where the cash you have spent on
      i dont play with tank, so no idea how it works, but if you want fast,
      why not use the switch channel.
      for a 2 pos'n switch, Up to firing, Down to stop
      or a 3 pos'n switch, Up for con't firing, mid for single shoot, down to stop ?
      XRB SR Lama
      Robotis Bioloid
      Robot Bear
        Acutally Dual rates are the best wayto get teh tank firing, if you want to add them to a switch you will have to mix in the switch to the corresponding channel, which is too much work.
        I have my tank running off my DSX9 and the way I set up is to have the dual rates for the gun channel low at 67% and high at 100%. Then do the tank's MFU setup in LOW rates.
        For a more detailed instruction, you can go here and read my post.
