Sob ... Sob ... I had to bury my A109 Coast Guard ... Was playing with my headspeed and turned it down too much ... The crash was dramatic ... Liternally nothing left ... managed to save the electronics including my SK360 ... It's now going into my 30-sized Ecureuil 2 ...
Augusta A109 Fuselage kit - what's this part used for?
Originally posted by loderunner View Postyou can refer to this link...good setup walkthrough by BlackTitanum.
although he is using the Slovenia Policiga paint scheme, the setup is almost the same.
http://www.helifreak.com/showthread....highlight=A109
Thanks a lot for sharing!
Originally posted by Super-Hornet View PostIf u are talking about the "sponge" for the tail boom, yes, the purpose of the "sponge" is to hold the tail in place in the fuselage. It is more like:
1. Absorb vibrations from heli to fuselage. Thus, do not produce unecessary "clanking" noise.
2. Hold the tail in place during applying tail pitch. (rudder movement).
I not sure about your "sponge", the one I have somehow cannot go in. I end u using DIY sponge that I get from Homefix.
Try to make sure the tail linkage do not rub against the fuselage. If it does, try move the heli a bit or use some sponge to relocate the tail a bit.
SH
Thanks bro SH!
Originally posted by kennethw View PostSob ... Sob ... I had to bury my A109 Coast Guard ... Was playing with my headspeed and turned it down too much ... The crash was dramatic ... Liternally nothing left ... managed to save the electronics including my SK360 ... It's now going into my 30-sized Ecureuil 2 ...
I just hope that i can get to fly mine decently...
Originally posted by pck View Post.....think i will go get those dish washing sponge for the purpose. i believe they are soft enough to do the job.
I use those black colored rubber, spongy thing that u use to stick onto the furniture "feet" or hifi set. It is stronger but still soft for damping/absorbing vibrations
EDIT: If u want to get dish washing sponge, I recommend u get those "Made In Japan", white colored, big block that it allow u to cut to the size u want type. Using those "white sponge" type, u can use alot (yet still light) and shape to the size u want and stuff it in to hold the tail. That "white sponge" should be stronger and harder than those typical yellow/orange colored square sponge..but still soft for damping.
White colored sponge is available in most shop. I know AMK Hub's Fareprice have them.
SH
Originally posted by loderunner View Posthi pck,
no prob!...i do find the manual useless when i was building this.
also, i don't think heli-artist kit come with sponge also....
btw. what heli are you using?....just check the CG before maiden. mine was tail heavy and i need to put weights to counter it.
cheers!
Practically all scale fuselage tend to be tail heavy. That is why u need to relocate the battery and/or avionics in order to balance them up. U can add weight if u want to, but I find that adding weight just for balancing is not good. I rather move the battery forward a bit. If not, I rather create cockpit or anything useful as a weight instead.
Example of things u can create in order to make it more "pretty" and as well as to create weight in front:
1. Cockpit
2. Pilot seats
3. Figuring as pilot or crew
4. Search light
5. Winch for rescue
6. Emergency inflatable floats
8. landing lights.
9. navigations lights avionics place in front.
10. Pitot tubing in front.
11. Wire cutter(s)
12. and so on.
SH
Originally posted by Super-Hornet View PostU can try that dish washing sponge...but I suspect it might be too soft.
SH
