Race Briefing
Hello everyone! SP Aerial League is the first of its kind in Singapore. A multi-rotor FPV race hosted by SP Aviation Club right in our very own backyard, Singapore Polytechnic!
It will be held on 27th June 2015, Saturday from 0900-1830.
The competition will be postponed if bad weather persists.
The league will consist of two categories, Novice and Open, these two categories allows both the more experienced and the beginners to have an equal opportunity to participate in a race!
Each category would allow multirotors of sizes ranging up to 450, The race track would include 270 degree roundabouts, crash-inducing obstacles and speeding through air gates.
So, all of you should be getting ready to don your FPV goggles or setup your FPV monitors, prep up your multirotors and juice up your batteries for this exhilarating experience!
Event Timeline
0900-1200 Practice Rounds
1200-1300 Lunch
1300-1430 Heats (Novice)
1430-1600 Heats (Open)
1600-1700 Finals (Novice)
1700-1800 Finals (Open)
1800-1830 Prize Presentation
Race Format
All participants will be racing in the heats. The total lap time will determine if you will move on to the next stage where you will compete against fellow participants to move on to the finals. Only the top 3 will compete with each other to fight for first place. Fantastic prizes will be awarded to the top 3 of each category!
Categories
Novice
The novice category is designed for beginners in the hobby to take part and compete at an easier pace.
Participants in this category will be flying around a simple race track plotted out with Air Flags.
Frame: 180mm - 450mm (motor to motor diameter)
Battery: 3 cell (11.1v) and below
Motor size: 25mm and below
Propeller size: 10 inch and below
2 blades per prop
No pitch limit
Open
The open category is more suited for season flyers who will be rewarded with precision flying as well as speed.
Participants in this category will be maneuvering around a race track filled with obstacles plotted out with Air Gates and Air Flags, and be required to perform tight 270 degree turns around the Air Flag.
Frame: 180mm - 360mm (motor to motor diameter)
Battery: 4 cell (14.8v) and below
Motor size: No limitations
Propeller size: No limitations
Race Regulations
All participants are required to submit their multi-rotors for safekeeping to prevent incidents where they are powered on accidentally and resulting in interference with others multi-rotors.
Video frequency channels would also be assigned by us to you so that we can have a smooth sailing competition without the hassle of clashing channels!
There will be an allocated repair bay for participants, who wish to work on their multi-rotors. All video transmitters must be unplugged in the repair bay.
All participants will be judged by a spotter with access to the video transmission. A time penalty will be incurred should any obstacles be missed.
In the event of a crash, the participants will be allowed to continue in the race if the multi-rotor is able to take off without any assistance.
In the event of any false starts, participants will be required to line up again and the race will be restarted. Any participant that false starts twice in a row will be disqualified from the race.
Participants will be given a time penalty of 5 seconds for missing an obstacle by more than 3 meters. For each race, participants missing more than 3 obstacles will be disqualified from that round.
Video Transmission
Frequency: 5.8GHz
Transmission output: 250mW and below
Participants may be required to change channel during each flying session.
RC Control
Only 2.4GHz radios are permitted.
Registration
Register for SP Aerial League via the form below, after which, proceed with the appropriate link to make payment!
Registrations would be closed on 21st June 2015, Sunday @ 2359HRS, then we would collate all participants' information and send out an email for confirmation of signing up!
Payment would be to help us out with settling logistics as well as ensuring that you guys have the best experience with our event!
Also note, by submitting this form, you grant your consent for your personal particulars to be used for the purpose of the said programme. We would like to assure you that we do not sell or give away any private information shared with us to any third party.
Form for registration:
Contact/Follow us
If you have any queries, do contact us at spaviation@cca.sg or you may have an open discussion below!
Do follow us at our Instagram page to learn more about us!
Event Timeline
1200-1300 Lunch
Race Format
Categories
Novice
2 blades per prop
No pitch limit
Open
Race Regulations
Video Transmission
Frequency: 5.8GHz
RC Control
Registration
Contact/Follow us
