Corona RP8D1 Receiver - Help Needed
    Originally posted by RCjoker View Post
    My original one only 7 channels..this one is 8 channels..am I suppose to leave the last one empty??
    yup.. no need to use all.. so what is this for..? some secret project?? wa^^^era?
    For sale
      Yup, I'm using channel 1 for throttle, channel 2 & 6 for aileron is u r using 2 servos for ur ailerons, if not just channel 2 alone.
      I can't remember which channel is for rudder & elevator. Will let u know when i reach home this evening
      Channel 3 for elevator & Channel 4 for rudder.
      Channels 5, 7 & 8 left untouched
        Good to hear it can bind to your Tx
        Hi Guys,
        I can't seem to link the RP8D1 to my JR9Xii. (Both r 72 mhz)
        1. Connect my ESC to Channel 1 of the Rx, Polarity is right
        2. Switch on my Tx
        3. Plug in the batt
        4. Rx blink twice, nothing happens after tat
        5. Depress the scan button once, nothing happens
        6. Depress & hold the button for 2 or more secs, nothing happens too
        Wat could be the problems?
        Hi jansonfinn,
        So eventually you got the Rx to bind with your Tx? That's good to hear. Yes, those Rx with the failsafe feature seems more finicky to get them to bind, unlike the 4-channel one which is so simple. You are not alone on enabling the fail-safe feature either. I tried to set it following the instruction sheet, but i don't think I got it set. Hope I won't need it in flight.
        Yes, the nice thing about these Rx is they're quite low-priced, and I like the fact that I don't need to worry about crystals. Though I think Corona needs to improve their build quality. I think I also had to press the scan button quite hard to eventually get it to bind, now that you mentioned it.
        OK, man, thanks for sharing.
        Pete
        ... It's in the Details... :>
          Thanks...I am looking at one of my walkera receiver and the channels are different..that why it made me confused. Will try tonight to fix up...
          Raptor 50 Titan
          Full Kasama Head and tail upgrade
          Futaba GY502
          Align 2 in 1 regulator
          MP5
          RevMax Governor
          Futaba S9254 digital servo
          Mini Titan
          Full metal head and tail upgrade
          Jeti 44 ESC
          Carbon rotor and tail blade
          Hitec 65HB x 3
          Futaba S9257
          Futaba GY401
          Walkera HM 60B
          3D capable
          Walkera 4#3B
          2.4GHz TX
          Flying in my room during rainning days
          Walkera HM 5-4
          Mini Park Flyer
          JR PCM 9X II
            I tried to use it for my walkera heli first....very weird, the 3 servos are placed different from mini T or Trex 450....
            Instead of having 2 servos infront ( near the motor ) the walkera has it the other way...
            Raptor 50 Titan
            Futaba GY502
            MP5
            RevMax Governor
            Mini Titan
            Jeti 44 ESC
            Hitec 65HB x 3
            Futaba S9257
            Futaba GY401
            Walkera HM 60B
            3D capable
            Walkera 4#3B
            2.4GHz TX
            Walkera HM 5-4
            Mini Park Flyer
            JR PCM 9X II
              if that is it so, u can trial n error n put the servo in 1 by 1 by testing it with ur tx
                I just bought 1 corona 8 channel 72mhz..... It works superbly on my 450SE.... Looking to get another one in the near future!
                BTW, I'm a Futaba user....
                Suck Squeeze Bang Blow
                20,000 times a min
