Originally posted by RCjoker
View Post
Corona RP8D1 Receiver - Help Needed
Originally posted by jansonfinn View PostYup, I'm using channel 1 for throttle, channel 2 & 6 for aileron is u r using 2 servos for ur ailerons, if not just channel 2 alone.
I can't remember which channel is for rudder & elevator. Will let u know when i reach home this evening
Channels 5, 7 & 8 left untouched
Good to hear it can bind to your Tx
Originally posted by jansonfinn View PostHi Guys,
I can't seem to link the RP8D1 to my JR9Xii. (Both r 72 mhz)
- Connect my ESC to Channel 1 of the Rx, Polarity is right
- Switch on my Tx
- Plug in the batt
- Rx blink twice, nothing happens after tat
- Depress the scan button once, nothing happens
- Depress & hold the button for 2 or more secs, nothing happens too
Wat could be the problems?
So eventually you got the Rx to bind with your Tx? That's good to hear. Yes, those Rx with the failsafe feature seems more finicky to get them to bind, unlike the 4-channel one which is so simple. You are not alone on enabling the fail-safe feature either. I tried to set it following the instruction sheet, but i don't think I got it set. Hope I won't need it in flight.
Yes, the nice thing about these Rx is they're quite low-priced, and I like the fact that I don't need to worry about crystals. Though I think Corona needs to improve their build quality. I think I also had to press the scan button quite hard to eventually get it to bind, now that you mentioned it.
OK, man, thanks for sharing.
Pete... It's in the Details... :>
Thanks...I am looking at one of my walkera receiver and the channels are different..that why it made me confused. Will try tonight to fix up...
Originally posted by jansonfinn View PostChannel 3 for elevator & Channel 4 for rudder.
Channels 5, 7 & 8 left untouchedRaptor 50 Titan
Full Kasama Head and tail upgrade
Futaba GY502
Align 2 in 1 regulator
MP5
RevMax Governor
Futaba S9254 digital servo
Mini Titan
Full metal head and tail upgrade
Jeti 44 ESC
Carbon rotor and tail blade
Hitec 65HB x 3
Futaba S9257
Futaba GY401
Walkera HM 60B
3D capable
Walkera 4#3B
2.4GHz TX
Flying in my room during rainning days
Walkera HM 5-4
Mini Park Flyer
JR PCM 9X II
I tried to use it for my walkera heli first....very weird, the 3 servos are placed different from mini T or Trex 450....
Instead of having 2 servos infront ( near the motor ) the walkera has it the other way...
Originally posted by johndyl View Postyup.. no need to use all.. so what is this for..? some secret project?? wa^^^era?Raptor 50 Titan
Futaba GY502
MP5
RevMax Governor
Mini Titan
Jeti 44 ESC
Hitec 65HB x 3
Futaba S9257
Futaba GY401
Walkera HM 60B
3D capable
Walkera 4#3B
2.4GHz TX
Walkera HM 5-4
Mini Park Flyer
JR PCM 9X II
I just bought 1 corona 8 channel 72mhz..... It works superbly on my 450SE.... Looking to get another one in the near future!
BTW, I'm a Futaba user....Losers whine about their best. Winners date the Prom Queen.
Suck Squeeze Bang Blow20,000 times a min
