DJI F450 quad with Naza, 1st test flight
    Originally posted by jackson chong View Post
    How do you install the driver for Dji Naza cause the first time it fail and it can't install anymore
    -Just uninstall all naza related programs first
    - restart your PC
    - must be online connected when installing the drivers and other software
    - make sure you know your PC- 32bit or 64bit. Download appropriate driver
    version according to your PC system
    - you must register and they will email you back with some code
    - after installing the driver, install Software assistant
    - do not cancel, turn off or interrupt the pc and connection while installing
    - The rest, please read the manual step-by-step.
      Driver
      Sorry guy, just want to find out how do you install the driver software for naza, I try many time but fail. Need help
        Driver for Naza
        I can help you if you can bring the notebook.
        I've got the updated driver with me.
        Noobie in R/C Stuff
        Life is a gift. never regret a day in your life.
        Good day gives you happiness,
        Bad days gives you experience,
        Both are essential.
          thanks for your reply, i'll try it again and let you know the result
            Everyone...
            Originally posted by silver View Post
            There are so many shop and people selling DJI products these days in SG, who is the official resellers here ?
              Taking F450 for a "walk" under the blk
                It's good to hear you have joined the multi-rotor community, congratulations on your purchase of the F550 & Naza.
                Here is the link to the DJI website where you can download the Naza manual & assistant software.
                剧白白(dji-hobby.com)是一个值得影迷收藏的影视网站,网站汇集了全网众多高清电影、电视剧、综艺节目、动漫以及热门短剧资源,剧白白影视大全在手,看片应有尽有!
                Here is the DJI website where you can download the instructions to build the F550.
                I hope you will find these very useful.
                  naza driver
                  if the windows has stop this device because it has reported problems. (Code 43) that means i need to send back for service. Need Help
                    Naza driver
                    Bryanlow don't mind can I have your contact no so I can bring my notebook and meet you. Thanks
                      Naza driver
                      Sorry guy I try so many time and it still cannot be done. I update the driver and it said ' the driver its up to date they can't locate a better driver' .I'm lost now but anyway I'll give trying . Thanks Bro's
                        Download the driver, make sure you know where you saved it. But better save it to you desktop.
                          Drivers Error
                          Amas if you don't mind can i give you a call
                            Can I have your contact no.
                              Finally I had the driver installed. Thanks for the help .May I know the setting of your dji naza because I'm having some problem when tying to take off.
                                Hi Jackson, its good to hear you have got the driver installed.
                                The default gain settings of
                                100 100 100 100
                                100 100
                                should be ok to lift-off.
                                I use these gain settings,
                                140 140 70 150
                                120 120
                                These work very well for me, but as each quad set-up is different you will need to fine tune each gain setting to get your set-up stable and flying your own style.
                                If you cannot lift-off at all, i.e. flip to the side, you will need to check the direction of each motor & prop and the orientation of both the Naza & the motors.
                                check & re-check with the Naza manual which is downloadable from the DJI website.
                                I hope this helps
