Where u guys buy the JGH BL motors ? I am waiting for a review on the Align motor too.
Align New Motor selling in Rotor
Originally posted by ammoNoise is not from motor, more like from gear meshing. check meshing if there is excessive noise
Yeah man, good gear meshing is very importance. the power consumption can vary by 10 to 20%.
My 2 cents about 450TH
1. some 1 in RC group have tried 4s for 450th, but the manual come with the motor restric the battery to 3S only.
2. definitely a good motor, but I think you would need a good ESC to go along. I've read from a china forum, that their 2200mah XXX brand battery giving them the flight time of 16 to 20mins with german brand ESC.( I've got 12 solid mins with 1700 Etec only, my AUW 750g)
3. when the rotor spinning at 2300rpm (2/3 throttle) the sound from the main rotor is fantastic, you will love it when you fly small circuit above your head ,medium frequency buzzing sound like a real AS350.
4. my previous 400LF 2800kv hover current draw was 7 to 8A, 450th definitely performed better than that ( I didn't measure, but I guess the range should be 6 to 6.5A judge from the flight time. )
5. 450th with 11t give me a very consistance performance for the first 10 mins of flight,unlike my previous 400LF motor, rpm deteriorate after 4th min.
6. have not try the 13t yet,so cant tell how powerful it will become.
Koon,
Are you getting 12mins with HS 2000rpm? or even at 2300rpm you are getting 12mins?
You should try my PolyQuest 1800XP (20C) and see the diff in power and flight time.
regards,
Jonathan
Originally posted by koonYeah man, good gear meshing is very importance. the power consumption can vary by 10 to 20%.
My brother did a test flight 10mins on
450XL CDE 325mm CF blade
CC35, GY401
HS55*3 & HDS-877
TP3S 2100 prolite
His comments:
1) MUch better performance than 400L or 420L(the best so far) but not as good as 450TH
2) Much cooler, after 10mins, Motor with heat sink is just warm, TP pack luke.
After 10 mins he said he will still stick to his 450TH and neu1105 :na but for $77, this a good catch.*~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~*
I am no Expert in 3D nor Sports flying. If you need advices on crashing, I am an Expert!
Active :T-rex450SE like, 450TH 11T & CC35, R146ip, HS65MG*3, GY401 & HS81MG, mH ProFrame & blings, TP3S2100prolite & 7CHP 72MHz mode 2, EOS 7i & LBA6. MiniZ.
Mike
Originally posted by Super-HornetOK... shall we mass order 450TH from Hongkong?*~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~-~*
Mike
regards,
Jonathan
btw. just passed the BEC and the motor to your maid.
