the heli-brudders fly at tampines industrial park on sat & sun from 6.30am onwards, in front of hoya building...listen for ah liang's thunderous blade fart, u really cannot miss it.
Getting Started
Originally posted by ATR76ers View PostNo subtrim on the trx....
In fact the only setup issue that I am currently facing is getting equal + and - on the Adjusting the cyclic swashplate limit...whereby the + can be much more than the - angle...Any idea what is the cause (any changes that at this point it is still back to Adjusting the swashplate servo centering being poorly setup?
Originally posted by tansh View PostWhen you go to step G setup,did you save the setting while still one of the servo selected?If not your new setting will not be save and you not able equal on step K.
Originally posted by ATR76ers View PostYes....after doing the minor adjustment for the necessary servo, I will have move my rudder stick until "no light" and press the button on the microbeast to move on to the next menu (this is as per what my limited understanding from the manual). Unless I am doing it wrong.
Originally posted by tansh View PostIn that case ur setting is not save on step G.You must leave the step G while red,blue or purple light still display.After that you able to get equal + and - pitch setup.
Originally posted by tansh View PostYes and easy to program without computer.
Correct me, but 88 pages of instruction is easy ?
I read the entire, briefly, and im sure ATR probably missed out something.. Thats why he is having problem.
ATR, i read page 47 and i think this section is crucial in order to give equal throws both positive and negative.I'm Remotely Controlled ...
Originally posted by blueangel View Posthttp://www.beastx.com/download/manua...T_3.0.3_EN.pdf
I have tried saving my settings in step G with one of the lights on...still not getting blue light for step L...or even angles for positive and negative...
Blueangel...tks for the advice...will take a look at what page 47 says....
Tks guys for all the advice for a newbie like me...
Originally posted by ATR76ers View PostHi guys...you are right...88 pages is not easy for newbie to understand. ...
Sigh....any other suggestions?
