optic 6 with stock honeybee cp2
    Meet me tomorrow w yr stuff abt 5.30 or so.... if u available during office hr also fine for me. Should be some setting.
    Mike
      Cp2
      Hi Mike, Can you help me with my CP2? I had a crash, replaced the bent main blade shaft in the center hub. Now, the lifting off is not as good. Brought down to LHS, they adjusted the main blade pitch, able to hover at their place. When at my home, full throttle still sitting on the ground. Sometime, does lift few inches. CP2 use to lift very lightly at half throttle in the past. Don't know what's wrong? Thanks...
      Chai
      Lets' moveon.......
        I work around Kallang area. Due to my nature of my job, i run abt ....most available time will be afternoon ard 2pm ..... give me a call. I will see what i can help
        Mike
          No number?
          Hi Mike, thanks for your help. No number to call leh....I work rather far from you, Pandan Avenue........My stuff is with me......My poor CP2
          Chai
          Lets' moveon.......
            hi chance the pitch angle is wrong. does the manual indicate anything about the pitch angle of the blades. u might wanna check it out.
            Hover: STILL many many
            FF: so-so; fig 8s, nose-in hover
            Crash (Major): 4
            Back to flying... let the goods times roll
              Worst manual
              Hi Membina, ESKY has the worst manual I ever seen....nothing mentioned at at.......
              Chai
              Lets' moveon.......
                peh se .... 92718979 Dun mind call me after 11.30 ...having a meeting at 10
                Mike
                  a nice guy from this forum once told me before that the ideal pitch angle for cp2 is -2, 4 and 9 at min, half and max throttle
                  i got my honeybee and glider
                    How to measure?
                    Hi dareaper, how to measure? I am new to heli.....thanks.....
                    Chai
                    Lets' moveon.......
                      u need to buy a pitch gauge to measure the angle, or else i read that there's some diy method to measure pitch angle at rcgroups, nv did go read abt it though.
                        Agree... they dun even tell u wat the gain & proportional adjustments are for. For your info:
                        Gain: Sensitivity of the gryo/reaction of the tail
                        Proportional: adjusts the amount of power 'proportional' to the main blade speed. ie... to adjust when u max out your rudder trim. + = makes tail go left. - = makes tail go right.
                          ok problem solved by mike, thanks alot to him
                          for those who are planning to get optic 6 for ur honeybee, juz decrease ur trimming for ur throttle to negative value if you get the same problem as mine. for mine, the 4 in 1 intialised only after the throttle was set to -15%.
                            Was trying to set up my HB T for use in Futaba 9c. Found tat the End POint on the throttle has to be set to 100/140 and throttle on reverse.
                            set to 100 the 4 in 1 will intialised, not sure wat u said abt the throttle -15% thou
                              different tx needs different settings i guess. for my optic 6 at min throttle, the honeybee intepreted that it is not at zero throttle. only after i (or rather, mike) adjusted the throttle trim to negative 15%, then the 4in1 intepreted the throttle to be set at zero.
                                CP2 sitting on ground at FULL THROTTLE
                                Hi Guys,
                                I found this from another forum. Apparently, someone is facing the same problem. CP2 sitting on ground at FULL THROTTLE. Follow this link.....
                                RC Helicopter Beginners Forum - ELECTRIC HELI HONEY BEE CP2 HELP?! - Hi all I'm new to the RC community and only bought my Esky Honeybee CP2 two weeks ago. Everything was perfect except that the battery only held through the maiden flight and wouldn't charge after that. Bought a new Li-PO and it's holding out. I have
                                Chai
                                Lets' moveon.......
