mCPX now avaliable with GOVERNOR!!!
    Dear fellow mCPX Users,
    I am proud to bring to you guys this great news. As the title has mentioned, the MCPX is now able to be Governed by a third party ESC...
    The current method of Governing that is accomplished at the moment is a
    "Reactive" Governor where the MCPX would increase\decrease its power once the rpm falls below the pre defined RPM...
    Using this method, known as flashing of the ESC, we now are also able to use the ESC to run a tail and main brushless set up without the need for a convertor. The exact potential as described by the guys a helifreak are as follows,
    The code supports:
    - Brushless tail. Get rid of that heavy SR120 tail motor.
    - Governed main. Get consistent cyclic and collective response in hard maneouvers.
    Other features are:
    - Parameters programmable from TX
    - Optional pitch to tail mix in governed mode.
    - Allows build of ultralight main and tail ESCs (<0.4gram).
    - Both v1 and v2 3in1 boards are supported.
    This is a completed model that i made to make sure this system works prefectly and it does...
    By xuen7 at 2012-04-15
    Yea i its kinda messy and all.. didnt wanna tighten the wires and wasnt confident enough then to re solder all over again.. much better after touching up.
    The brushless tail...
    Latest Microheli Advanced X frame and Advanced X swashplate, Titanium Main shaft and ...
    Finally my very own mCPX Mama-shop that recently opened up right beside my bed... ( used to be ex-gf make up area... so yea also got spare cash from being single to spend on my hobbies.. )
    Regards,
    Xuen7
    SELLING
    2 x Brand New ThunderPower G6 Batteries 65C 5000mAH
    Kontronik HeliJive 120HV ESC
    Brand New Mcpx Upgrades
    Flashed XP-12A for MCPX Governed and Brushless Conversion
    Flashed XP-3A for MCPX tail brushless Conversion
    BUYING
    MCPX parts / kit etc..
    Burned MCPX Mainboards
    "Learning the art of forgetting for the sake of remembering"
    super wow. what's this obssession with the mcpx?
    Heli-ADDICTION:
      Bravo bravo. Bro. Cool
      I want to learn how to HOVER...lol
      Training orientation MSRx with DX8 , Training up to TDR....Realflight 6.0
      May Ah Pa bless me with the will to fly and stop buying Heli till i can hover...lol
        Wow... I'd love to see videos of your micro shells in action.
        Helicopters: KDS 450QS+Tarot 450FL+ZYX4.0, XK K120, HiSKY HCP100S, HP100BL, V922, HCP80
        Multirotors: Wingsland MiniVet, CX-20, NightHawk Pro 280, ROA Parkour 280, Eachine Falcon 250, Eachine Racer 250, Eachine Assassin 180, Tarot TL130H1, DP4X-124, Skyartec Butterfly
        Planes: Volantex 757-4, F16 EDF, F959, F939, HiSKY HFW400
        Transmitter: Taranis X9D+
          Sorry for the late reply... literally overwhelmed by the amount of people asking questions and stuff about the mcpx.. gonna be a long night.. 2 more mcpx to mod.. seeya
          Videos can be done anytime just need to wait for Ryu to be free hahaha
          Regards,
          Xuen7
          SELLING
          BUYING
            Operation manual
            Normal operation:
            Once the battery has been plugged into the 3 in1 board,
            - Ascending Tone is heard
            Throttle needs to be on Throttle Hold before the initialization can begin
            Next release Throttle Hold to begin Initialization
            - Long Beep is heard
            The maximum throttle during this interval sets the throttle target for the governor.
            Once you have set the target, flip on Throttle hold again to end the initialization mode
            - Long Beep is heard followed by the Motor Powering up
            Entering programming mode:
            Full throttle to enter into programming mode
            - short beeps
            Throttle hold to comfirm entry into programming mode
            - short beeps
            Full Throttle again to begin programming mode
            Programming mode:
            This works very much like your castle programming mode.. the beeps represent the number in the menu.. Throttle hold to comfirm entry
            Programming functions and parameter values:
            Programming parameter value table main:
            Function
            1 - Governor P gain 0.38 0.50 0.75 1.00 1.50
            2 - Governor I gain 0.38 0.50 0.75 1.00 1.50
            3 - Governor mode Tx Arm Off - -
            4 – Low voltage limit 2.7V/cell 3.0V/cell 3.3V/cell - -
            5 - Startup power 0.50 0.75 1.00 1.25 1.50
            6 - Pwm frequency High Low - - -
            7 - Rotation direction Normal Reversed - - -
            8 - Input pwm polarity Positive Negative - - -
            Programming parameter value table tail:
            Function
            1 - Tail gain 0.75 0.88 1.00 1.12 1.25
            2 - Tail idle speed Low MediumLow Medium MediumHigh High
            3 - Startup power 0.50 0.75 1.00 1.25 1.50
            4 - Pwm frequency High Low Damped* - -
            5 - Rotation direction Normal Reversed - - -
            6 - Input pwm polarity Positive Negative - - -
            *: Only enabled for ESCs specified for 1S operation only. Default for the ESCs where it is enabled.
            In the governor “tx” mode, the throttle setting will set the speed target for the governor.
            In this mode, the throttle curve when flying should be flat.
            In the governor “arm” mode the maximum throttle seen during the arming sequence will set
            In this mode, the throttle curve when flying does not influence headspeed.
            Throttle curve can be set for the desired main to tail mix (this mix is in the mCPX 3in1)
            Governor P gain sets the proportional gain for the governor.
            This setting controls the gain from speed error to motor power.
            Governor I gain sets the integral gain for the governor.
            This setting controls the gain from integrated speed error (summed over time) to motor power.
            Document rev 2.x
            Tail gain scales the power applied to the tail motor for a given input.
            Beware that a low tail gain will also limit the maximum power to the tail.
            Tail idle speed is the speed of the tail motor during the delayed stop.
            High pwm frequency is around 20-25kHz, and low pwm frequency is around 8-12kHz.
            One benefit of using a low pwm frequency is that the step from almost full power to full
            power becomes smaller. On the other hand, 8kHz is in the audible frequency range.
            The damped pwm mode for the tail makes the motor retardation much faster.
            It is only supported on some ESCs (where both nfets and pfets are driven directly from the
            MPU) .
            If for some reason there is an error in the eeprom/flash write operation (e.g. due to loss of
            power or low voltage), defaults will be loaded.
            Regards,
            Xuen7
            SELLING
            BUYING
              Due to the overwhelming response, i had to DHL spares to get them in time to meet the demand.. phew thankfully DHL came fast!!!
              Uploaded with ImageShack.us
              Regards,
              Xuen7
              SELLING
              BUYING
                Did I see one or two of those pack has my name on it..
                Avant Aurora (E1)
                Avant Aurora (E2)
                Mcp X
                GAUI X5
                LOGO 550SX
                WTS
                  Those nah... those are brand new and unflashed stuff bro... as worthless as it is to any of us.,
                  Yours is right here.. Brand new and Flashed with the latest software and programming options...
                  By xuen7 at 2012-04-17
                  Oh and these are the avaliable options..
                  Regards,
                  Xuen7
                  SELLING
                  BUYING
                    A tip for optimizing governor performance:
                    You can decrease the rise time of the feedback control system by decreasing the proportional gain P to its minimum of 0.38 (from the default of 1.0). This results in much quicker return to the desired headspeed when disturbances are introduced (e.g., under sudden collective/cyclic input). Governor performance greatly improves.
                    When testing using a tachometer with a governed headspeed of 6300 RPM (2S, HP08S, 9T), moving from 0% to ±50% pitch results in the following delay before headspeed returns to 6300 RPM:
                    Proportional gain P = 1.0: ~2 seconds
                    Proportional gain P = 0.38: < 0.5 seconds
                    Increasing the integral gain resulted in no noticeable improvement, but decreasing it resulted in much longer rise time (longer recovery to 6300 RPM), as expected.
                    Note that you should play with the gain to determine the best value for your setup. A "cut-down" modded mCP X, for instance, may behave poorly with such low P gain.
                    Theoretically, lower P gain should also result in more overshoot and longer settling time, but the head's inertia (system damping) prevents this, as the motor cannot speed the head up fast enough to see it. Also, there is more risk of control loop instability.
                    Regards,
                    Xuen7
                    SELLING
                    BUYING
                      MINE!!!!
                      Just converted my batteries to use JST plugs. Power feels more constant now
                        Sweet looking heli bro!!! hehe glad you liked it.. anyways do keep me posted on new solutions or problems or just a new build..
                        btw i tach HP06v2
                        70% runs at roughly 5421rpm
                        50% runs at roughly 3533rpm
                        anyways i have HP08s on its way via either fedex or dhl.. will let you guys know it its worth the buy... damn no sign of tdr..
                        Regards,
                        Xuen7
                        SELLING
                        BUYING
                          btw i tach HP06v2
                          Regards,
                          Xuen7
                          SELLING
                          BUYING
                            sweet looking heli, silvialite. really nice.
                            Heli-ADDICTION:
                              Dear Fellow MCPX Fanboys,
                              Due to a recent changed of events, the MCPX mama shop shall ceased operations effective immediately..
                              Your overwhelming support has been much appreciated.. Follow up services will still continue as per normal and all after sales services will still be provided as per normal..
                              Regards,
                              Regards,
                              Xuen7
                              SELLING
                              BUYING
