Hi all, just gotten myself a e550 wif extended boom (to run 600mm or 610mm blades), and was wondering wat kind of setup will be suitable for it. As I am just a beginner, and the electronics used will most probably be for sports flying, please advice me on the electronics to be used. Budget wise, not very big
Below are some ideas that I am looking at..
Motor - scorpion hk4025-740kv
ESC - CC85HV (or is the stock BLC-65A ESC enough?)
Cyclic Servos - HS5625MG or HS5645MG or HP-DS20FMD
Tail servo - HP-DS20GMD or 8900G or ???
Gyro - GY401 or JR770T or Solid G or ???
BEC - Turnigy 15A bec (from Genexis erpator build thread)
Batts - 2 x 5s 3300mah Zippy batts
Do leave some comments on the above setup and if possible and recommendations.. My intention will be that hopefully the above mentioned setup will enable me to move to intermediate level.
Thank you all..
Thank you all..
Maybe can look at the ones you recommended as my second pack.
