hi guys, i just bought a new lama v4. crashed it several times and went through a couple of blades already. i was just about to get the hang of hovering it, b4 it had a minor crash again. now, i have some problems. the heli wont even take off when applied full power. i changed the blades and everything looks fine. but it just wont take off. i notice that the led light(batt indicator will turn from green to red) on full power. is there something wrong with my batt? i have 2 of the 800mah lipos and they are very new. could it be a batt problem? i use the supplied esky charger to charge it. is the batt suppose to get warm when fully charged cos mine did not.
beginner need help, lama v4
Originally posted by joe1981hi guys, i just bought a new lama v4. crashed it several times and went through a couple of blades already. i was just about to get the hang of hovering it, b4 it had a minor crash again. now, i have some problems. the heli wont even take off when applied full power. i changed the blades and everything looks fine. but it just wont take off. i notice that the led light(batt indicator will turn from green to red) on full power. is there something wrong with my batt? i have 2 of the 800mah lipos and they are very new. could it be a batt problem? i use the supplied esky charger to charge it. is the batt suppose to get warm when fully charged cos mine did not.«Kira'sHanger™®»:
HK450MT ( awaiting elecs)
Originally posted by joe1981hmm thanks for the lipo tips guys.. but still wondering why my heli cant take off.. anybody got any idea? im very new in this electric heli hobby.. i bought the heli from a friend. anybody knows of any shops that i can send my heli in for a 'check-up'?«Kira'sHanger™®»:
but still the best is to bring it the shop for check up«Kira'sHanger™®»:
Originally posted by kiratimebut maybe its ur motor thts having the problem as you said u hav crashed it before so the motor might hav been damgaed even though it seems fine...
Lama V4
Hi! Probably you should try to check the following:
1) If you are in mode 2. check your throttle trimming lever on your right hand side. whether is it in the center or not. Most probably ( I think! ) your trimming for your throttle is at the bottom or near bottom.
2) Your batter probably already over use. Lipo battery cannot be drain to its minimum voltage below 3.7V for each cell. Check with your multimeter what is the voltage from your battery after a full charge.
Originally posted by Cessna584Hi! Probably you should try to check the following:
