hello guys,
assumming the Pitch curve for both Normal and Idle up modes are the same from above mid stick, when u switch from Normal to Idle up, ur swashplate should not move right? cause in theory there is no collective change.
so if the above is correct, why is it on my heli when i switch to idle up from normal my swashplate will move, i.e, my channel 1 and 6 (aileron and pitch servos) move upwards and my elevator servo moves very slightly down. the end result on the swash plate is very obviously tilted back.
i can subtrim my heli so my swash is level in Idle up but when i switch back to Normal the swash becomes tilted again due to this movement in servos.
this really stumps me.. anyone got any ideas?
CHEERS!
CHEERS!
