Hi all,
I need your advises here, even those w/o Belt CP experiences.
After fixing everything up, trim all the linkages etc², I notice that the head is a bit sticky to turn. Hand spin would stop the head almost immediately that the auto rotation would definitely not work. Unlike my old DF #60 head would spin on a puff blow to it's blade. I've tried to loosen the belt and even took out the belt seems it doesn't help that much. I saw some thread others having this problem but most point to the belt.
Then my hands got itchy. I dismantle the head set apart. I checked and open up the swash plate to see any binding or dust. It was quite ok though it's not spinning freely. Then I notice the culprit was either the oneway bearing or the gear sets! There's nothing in the way but it wasn't spinning freely in my hands when the two gears are attached with the oneway bearing in them.
How can I fix this? I'm afraid that replacing either would end up the same, CNC perhaps? Tried wd40 too and still doesn't help that much. I got my kit from RCE and I think only Pips has the spares now. Please help to advise, I think this is the reason why my hobbywing 30a got very hot everytime. Even the connector of the esc<->battery gets hot...
