Originally posted by ammo
View Post
Logictech LTG-2100T Gyro setup guide
After adjusting the servo limit for both sides of the slider, remember to adjust your EPA back to normal eg. from 150 to 100 in case of DX7.
My Logitech2100 is sweet as hell. Able to do comfortable reverse flight on my CopterX450. The holding is great. It seems my tail rod was too soft. I changed to the Align tail rod and now it is fine.
As for the 'expo' feeling by default, I have learnt to get comfortable with. Piro seems to be naturally dampened around midstick.
Originally posted by Sirod View PostKen,
Thanks for clarification, I got it.
So adjusting the ATV/EPA will affect the speed at which the slider will hit their
stops and in turn affect the piro response rate, assuming the servo speed
is fast enough follow the change right ?
Sirod
However in flight, it's a slightly different manner, which also leads to the biggest difference for normal/rate and heading hold behaviours.
But i'll leave it alone for now
if it is the 2100t u r talking abt, it can be mounted in any orientation as long as it is flat. i mount mine upside down with the led running from left to right.
gyros sense rotational motion around a axis. it works as long as the axis is rightFor sale
having a bit of issue with my lgt2100. cant seem to set it up nicely. try with a hs81. but when i move the rudder, servo dun seem to move nicely lik tt, a bit jerk jerk. tried with another servo oso same.
so did i setup wrongly? i tried to follow the guide.sigpic
Helis:
Heli 1: Trex 450SE V1
Status: Fit
Date of Operation: 27 JULY 08
Radio: Optic 6 + Electron6
Batt: Zippy-H 3s 2200mah 20C
help!
ok. this is the issue.
My lgt2100 cant seem to work as well as other said it could be.
lgt2100 + hs81: tail hold well but the tail reponse seem to be a bit retarded, as in it wont stop immediate, tend to overshoot. especially the left rudder input.
gy401 + hs81: the reponse was sharp and tail hold well.
so basically i onli swap the gyro. i believe lgt2100 should be working much better. tink tt should be my setup issue.
setup of lgt2100 as below:
servo speed: third led
rotate rate: sixth led
direction: it correct
servo limit: setup to almost juz touching. btw, should it be done it non-hh mode or hh-mode. any diff?
gain: 70% on my tx, abt 2nd led on the gyro.
so any expert out there can offer me some kind of advise?sigpic
Helis:
Status: Fit
try 85 and see if it wags.. if it does, u'll probably need a digital servo like ammo said. I too gave up on the hs81For sale
haha. okok. in fact main thing i wanna ask is whether hs81 not suitable for use for lgt2100. den after typing so much i forgot to ask tt.
k guys, tt settle all le. guess i stick to my gy401 until i gt another servo for my lgt2100.sigpic
Helis:
Status: Fit
compatible with esky cp stock tx/rx?
yeah im a dumb noob. I wanted to make the worlds best RC heli out of a esky bely cp (sacarsim implied) so I got the 2100T and its not letting me get into the menu, however it lights up and the TL green LED turns on and the 3rd led flashes red. So do I need to invest in the DX6i or is there some way around that temporarly, im ordering the DX6i tonight but I just waited 2 weeks for this to get here and Im not looking foward to waiting another 2 weeks for them to ship a TX and RX to Iraq.
Ltg-2100t/mks Ds9670
I'm battling my tail since day 1. I just flown my heli for 4 flights I think. From ground to air upon hovering, the heli spins 360 degrees before it gets the hovering collective. At the air, the tail has slow response with my rudder stick, and the tail doesn't hold. I even crashed at my last flight. I changed main blade, feathering shaft, flybar rod, main shaft, one see saw mix arm, swash plate, main gear, front shaft pulley. So much frustrated with this setup
Now, the problem now is different. I can't even have the guts now to fly the heli because the tail vibrates even when heli is at the ground. The tail pitch slider even move to the left (head to right) as it is vibrating. I removed the main blades, tail blades, tail grip & tail blades. I can see the servo arm vibrates and reflected in the tail pitch slider vibration and still moving to the left. I even change the GAIN from 85% to 99% but the problem still exists.
Ammo, could you help me on this one?sigpic
"Sky's the limit"
