how to increase piro rate on gy240??
    any tips?
    Helis
    Logo 500 3D
    First, make sure you run a high enough headspeed...
    Make sure your EPAS are 100... for rudder channel
    Mechanically wise, make sure you get the max throw on the tail, meaning.. the max pitch for the tail rotor..
      my head speed is 3k and all throws are full epa are all 100.....any other way??
      Helis
      Logo 500 3D
        Pretty norm for gy240 to have slow piro. Up your epa and d/r all the way above 100. Th piro is not controlled by headspeed. Its controlled by e gyro
          Newbie here. Is it always better hi pyro? What is pyro? Sorry, but reading this thread bugging me to know what it is about .
          Regards,
          Arto.
          Dynam Hughes 300 fp with stock blades and GWS DD tail upgrade...
          TX: 72.830MHz, mode 2.
          Can hover already, now learning orientation...
            pyro rate is the rate at which the heli turns....
            High headspeed is good for maintaining constant piro rates
            can also lower the gain of the gyro to get faster piros
            else you can set a DR of 120-140%
            TREX 500 ESP
            Futaba T12FGH
              my tail pitch slider is all the way to the end already without binding
              Helis
              Logo 500 3D
                and if i lower my gain my tail dosent hold well or rather very bad
                Helis
                Logo 500 3D
                  change gyro?
                  But rookie as I am, why should the gyro affect piro rate? I thought the pitch of the tail blade should affect piro rate in total?
                  JR PCM 9XII
                  35.150
                  BEAM E4
                  HS65 Cyclic
                  Futaba S3154 Tail
                  Scorpion 2221-8
                  JETI Spin 44A
                  JR RS 77
                  Logictech 2100 TL Gyro
                  Thunder Power TP2070-3SX
                  A Bottle Of Guts, Neat.
                    Max out your D/R and EPA. If that fails then you have to use a longer servo arm. For the 240, don't worry about binding on the ground. When in flight it won't bind.
                    Hope that helps.
                    -Feda Dragonfly
                    -Hornet 2
                    -Pilot OK Turmeric
                    -Zoom Zoom 4D
                    -Hornet X3D
                    -Hornet X3D (yet to setup!)
                    -Formosa 1
                    -World Models Spot On 50
                    -HB King 2
                    -World Models Groovy 50 F3A
                    -RICCS F18 EDF
                    Controlled by 9CHP
                    (Temasek Poly AMIG)
                      If u really want to kiasu on piro and yet still using G240, if u already max out your Dual Rate, alternatively is to use bigger tail blades or more tail blades.
                      SH
                        Originally posted by glenn cain
                        change gyro?
                        basically the gyro controls your tail movement, so when you input a rudder signal, you are actually telling your gyro to turn your rudder, and then your gyro will in turn command the tail to turn. so the gyro is the one controlling how fast the tail will turn.
                        think logically... if you sent a rudder signal and a wind came along, the gyro will have to act up to hold the tail during the turn, right? if it gave the heli an uncontrolled full rudder servo throw, then your tail won't hold in a turn when there's a wind... this is exactly it if you turn off HH.. or for gyros like PG-03.
                        the pitch slider will affect piro rate only in GY401 where you can set limit. for GY240, like Fit said, won't bind in flight that's because the gyro controls the piro rate and it's piro rate is rather slow, thus requiring only very minimal servo movement.
                        only way to get higher piro rate is to increase rudder dualrate and EPA/ATV.. whatever your TX calls it.
                        pls correct me if i'm wrong
                          Here is what I previously did comparison with GY240, GY401 and PG-03 during comparison of which gyro is suitable for cyclic stability:
                          The response speed of GY240 is slower than GY401 and PG-03. With that, when u send signal move the tail (or change tail blade pitch), the response is slower and thus the piro speed is slower.
                          Then for GY240 and PG-03, it has a situation whereby when it start to piro, the gyro actually sense the movement and offset some value back instead. That is why alot of people said that for GY240, it will not get binding when in flight as compare to stationary. For GY401, when u send signal to tail servo to move, it will move the tail and ignoring the gyro sensing (in other word, it does not offset or compensate back...like GY240/PG-03)
                          All that above will make the piro for GY401 to be faster than GY240.
                          SH
                            BTW, here is the link to my previous post:
                              SH
                              cool! but somehow, the gyro must still be active when you send a rudder signal otherwise when in HH mode, the tail will be affected by wind during a turn, right?
                              so can i say that it is something like... the delay settings on the GY401 is to tell the gyro how fast (resolution) it should detect the piro and issue the next servo command (whether to speed up the piro or not... ), so if the delay is high, the detection rate is slower (to compensate for slow servo movement) and thus slow down the piro rate?
