i just had a boom strike with my x400 with standard boom 322mm should i upgrade to the trex 347mm boom does it make a difference if its shorter or longer and what blades im going to rotor soon
boom strike
Heli
Plane
PT-17w : Sold
Buggy
Charger : Tahmazo T15
Balancer : TP205
Long or short boom has the equal chance of boom strike.
Boom strike happen when our main rotor head tilted backward (see below) and the blade kisses the tail boom. So, long or short boom, the height between the blades and the tail boom is the same.
There is a situation whereby when u use longer blades but with short boom, the main blades tips hit/kisses the tail blades.
EDIT: There is one situation that you might think long boom causes more boom strike whereby your tail boom is longer, u miss judge the distance of the the boom and when u do emergency landing or hard landing in a tilting angle, your tail boom hit the ground much earlier than before. That sudden "banging" on the tail will cause the main blades to hit the tail instead.
Boom strike is more frequent to happen if you have soft O ring damper.
Note:
All R/C 2 bladed with flybar+paddles design I see so far follow the "Teeter" design. Think of "see-saw" in playground. When one blades goes up, the other goes down. In real/full size heli with teeter design (like Jet Ranger and UH-1C), their rotor head is far more higher than those multibladed head due to prevent blades hitting the boom.
EDIT: Long Boom compare to short.
Advantages
Longer boom allow you to use longer blades.
Longer boom also increases the piro-rate or tail power.
Dis:
Heavier on the tail.
May look ugly to others.
SH
Originally posted by Super-HornetLong or short boom has the equal chance of boom strike.
Note:
Advantages
Dis:
SH
AIR
HB K2 - Service
CopterX 450 - Hanger
IFO - Service
Walkera H05 mini plane
JR X3810
LAND
Kyosho Javelin - Garage
Tamiya TT01 Subaru WRX - In Service
Tamiya M03 Hello Kitty Swift - For wife
Cen Mini Madness - For son
Team Losi Speed T - In Service
Tamiya TamTech Frog
Sanwa MXA
Sanwa MX3S
Losi 2.4GHz
Crash Lander
Can crash land anytime anywhere
