Please recommend 3D main rotor blades for Raptor 50!
    Hi all, I am using the Funkey Fibreglass 600mm (the grey ones).
    Any good blades (pls include $) to recommend?
    best I know...MS composite 600s $130+
    Some people swear by MAH 600s $100++ ( Mail order )
    Some will like the original black/white TT600s ( Dunno price )
    Some V blades.....V Blades, paddles & tails going for about RM500 )
    For me...I use the same ones as you..cheapest to crash..and takes quite a bit of abuse
    TREX 500 ESP
    Futaba T12FGH
      TT 60s, they are the cheapest of the carbons...
      very good blades, better than the carbon tech from rotor
      too bad my friend broke it while 'trying to fly'
      if you order any blades, let me know
      sar.ratha@me.com
      DEVIL
        tt600s are SGD 105 less shipping
        by the way, they have a nice white ring effect when they are in the air
        sar.ratha@me.com
        DEVIL
          where to order those blades ?
          [B]Kenny[/B]
            I don fly heli but I know ppl always go HS looking for MS blade.
            Mike
              seen some SAB in action....flyer told me it's a lot 'smoother' than Funkey.....can be found in Cyberheli.com
              I personally prefer black carbontech funkeys with 3D tip (tapered tips), but like Art mentioned, silver funkeys are cheaper to whack...I find them good enuff for most maneuvers except hard tic tocs where they tend to flutter a bit, resulting in poor timing & response.
              [SIZE="1"]
              [url]www.dxnmedia.net[/url]
              [/SIZE]
                Fluttering of blades ... do check your linkages Hehe, had bad experiences of fluttering during 3d manv when my double links was a little worn and some screws not fully tighten. May help a little if you try rebuilding your head and check if grip bearings are worn.
                  Well, if there's a problem in the rotor head setup, then changing blades also won't solve the fluttering issue during hard pitch changover maneuvers.
                  And you can also hear the 'warrrrpppp' sound of blade farting being very different when u try the black funkey carbontech.
                  The problem with Funkey FG (silver) blades isn't really obvious with 600mm, but when u go longer like 680mm for 90size, then the weakness of the funkey FG blades is amplified.
                  If your pocket can handle, and u think u're up to the stage of hardcore 3D, it's always better to go MS composite 600mm...Got a pair and they're excellent...but I can't bear to use them....
                  [SIZE="1"]
                  [/SIZE]
                    So many choices... so little money
                    Thanks for the responses!
                    Ethinger: Where can I order TT carbons?
                      try www.helihobby.com
                      if u order let me know!
                      i want them for back up
                      sar.ratha@me.com
                      DEVIL
                        i got them from helihobby.com
                        i also got MAH 710s from there,
                        which has even better white ring effect!
                        sar.ratha@me.com
                        DEVIL
                          i didnt have a close up pic of the tt 600s sorry,
                          that was the last time i saw it in one pice each
                          and the MAH 710s
                          sar.ratha@me.com
                          DEVIL
