PCM : Erwin XL ultralight
PCM gliders
we are dealer for PCM.at.
Please feel free to contact us if you are interested in any of their gliders. We can work something out for you.:smile3:
Regards,Asia Pacific Hobby Pte Ltd
[URL="http://www.apachobby.com"]http://www.apachobby.com[/URL]
Enquiry Email:
[EMAIL="info@apachobby.com"]info@apachobby.com[/EMAIL]
Originally posted by JYHELI View PostNice or not , good review ?
ANyone getting one ?
Jonathan
I am not sure it is suited for hotliner style flight or aerobatics."Always fly with a responsible attitude. You may think that flying low over other people’s heads is proof of your piloting skill; others know better. The real expert does not need to prove himself in such childish ways..." - the Multiplex Build Manual
Jonathan
"This plane is one hunking piece of carbon and not 2.4 gig friendly.
I flew it from 8 to 40 mph winds and it has the standard carbon joiners and steal ballast joiners. I flew the plane for 3 years and had one landing that cracked the fuse but I found through rcgroups a replacement fuse in Orange and just had two flights on it. On one insane flying day a turbulence ended it in a fence on the left wing. The wire cut a a two inch path in the wing. Mart fixed and it is as good as new ( even that the paint is not looking perfect but you don't notice it 3 feet away). I would say the plane is a 7/10. However, I am the only guy in the Bay area having one. .
This plane is the most beautiful I ever had and you point it and it goes there and it thermals with the nice dihedral like the diggins. It is not a speed demon will not break the 45 sec barrier in f3f even if you put a rocket on it. It is also not good for hard DS the servos in the tail will not push the elevator up at certain speeds. It is the best allrounder that you can ever have and it is robust."Irony = displaying enough parking coupons on your dashboard but getting fined for littering when you throw the stubs on the floor
My Erwin XL Ultrlight have arrived...but I am out of town till later this week.
Got my power systems on its way also.
Now I got to figure out what servos I should be using ......
Was thinking of using DIgital Servos on this one ...Any advantage for Gliders ?
I know for sure on Heli I only use digital....on my Taser it is all analog servos.
Anyone try this : Hitec RCD! Introducing HS-A5076HB Digital Slim Servo.
http://shop.rotor.com.sg/show-detail.asp?prodid={107D87E9-5FA1-49E7-A756-E45C59DE7696}&pn=2
The recommendation are :
Servos for the wing
Erwin XL slope:
Futaba S3150
Graupner DES 448
Erwin XL ultralight + elektro:
Dymond D60
Hyperion Atlas HP DS09SCD
Servos for the V-tail
Hitec HS65HB or MG
Robbe S3107 (weak)
Graupner DES 281 ; C2081 ; C261 (these servos will fit into the gap of the servo board)
Erwin XL ultralight Elektro
Dymond D60
Nice big plane!
Digital servos like same as in helis , faster refresh rate but its not so important as in helis where fast response are needed. Good analog servos like the D60 works very well. Some of the guys are using the D60 in very fast F5D planes so no worries.
We used to skip the hitec 5/125 wing servos as they used to not center well and strip gears easily. This new model looks better, cant comment as have not use it yet.
Yours is the ultralight version so keep it as light as possible and it will perform as it is designed to, skip all the servos that are more than 20grs. Use D60x6 as recommended in the build manual http://www.pcm.at/downloads/Bauanlei...BA_Engl-03.pdf for the ultralight.www.facebook.com/groups/BRslopers
