Originally posted by throttle
View Post
Pheonix 2000 glider
Originally posted by throttle View PostAny idea on why my glider will go vertical on full throttle. The motor is not power enough it came to a stall on air.
Any idea?
Also, how do you fix the plywood piece? you epoxied? will it be strong?
Fixing of plywood peice for Phx 2k
Any idea?
plywood piece
Originally posted by dloh View PostMy original plan was to use the 5 min epoxy to glue the plywood "firewall" to the plastic fuselage, it came undone later, so I just leave it,..the entire setup is held together by the mounting screw, so the setup will be something like this...the plywood will be sandwiched between the mounting screws with washers , the plastic fuselage the metal fuselage and finally the motor, in that order (check the pic I posted to see what I mean), so its not going anywhere. If u are abit kiasu, u can always add alittle thread lock to seal the deal.
,..the entire setup is held together by the mounting screw, so the setup will be something like this...the plywood will be sandwiched between the mounting screws with washers , the plastic fuselage the METAL DISC BRACKET and finally the motor, in that order ...so far, no proplem with this setup
Originally posted by throttle View PostI see, so what did you use to cut the fuselage open and how many mm did you leave to epoxy the plywood and the fuselage, also are the plastic fuselage and plywood can be seal or you screwed it together?
One last time, Motor (outside), then metal bracket, then fuselage, then plywood disc, and lastly mounting screws with washer,..mounting screws will be from inside fuselage (BTW entire mount is secured by 2 mounting screws with washers..of course the screws are longer than those that come with kit to ensure everything is securely fastened together)
Originally posted by dloh View PostI did not cut the fuselage open, like I mentioned on my earlier post, when I installed Emax GT2218/09 1100KV Outrunner Brushless Motor (after my stock motor was burned), for reasons unknown (maybe overheat), the motor spin inside fuselage and make a need cut through the fuselage, so just to make everything simple....entire mount is secured by the mounting screws..no epoxy whatsoever, to me thats enough since this method of securing hasnt come apart yet...plus the fact that now my motor is outside/infront of the fuselage, no more overheating issue.
Im thinking of fiberglassing the nose intead as for now the only prob i have ia vibration on full throttle, but sometimes it vibrates sometimes it did not, so i guess the nose where to motor is mounted is flexing.
vibration
