With the mistakes learned in the failed attempt, I got the 1.5L H20 bottle and tried again. Bearing in mind the following:
1. The canopy is formed when the bottle is shrinked, the result would be a smaller bottle - consideration: Go for a bigger bottle
2. When heated, the shrinking of the bottle will take up the shape or any space inside the bottle - consideration: Squeeze foam plug as tightly into the bottle as possible. All air gaps should be filled with scrap foam
3. Your significant other half will feel neglected when you spend too much time building planes - consideration: space out the build time, clean up after each build session, buy her a big present or two
As the foam plug was realtively easy to shape, I manage to finished this canopy from start to finish in about 1 hour total.
The empty air space inside the bottle, after putting in the foam plug, was filled with as much scrap foam as possible. The whole bottle was then immersed into boiling water for 1 minute.You will hear the shrink noise, kind of like a well-mannered fart, when you put the bottle into the water.
The result was very good! Success, at last!
The canopy edges were cut off with a kitchen scissors and the outline of was traced as per the canopy in the fuselage. The black trimmings were stick on with the leftovers of the decal from my Formosa.
Now, I can safely announce that I know how to make a canopy.
I am very close to maidening the Guppy glider, need to go hobby shop and buy a pair of new folding prop first.
MS
MS
