Fuselage
Lots of work to be done for the fuselage.
There are 2 main sections - the Pod and the Boom. The Boom is from a 6mm CF tube, at the end of the CF tube is the vertical stabilizer. Holes were drilled for the push rod of the elevator and the rudder. Tape round the area to be drilled, this is to ensure the thin wall of the CF tube would not be damaged.
The push rod tube+wire in the tube is secured inside the vertical stabilizer. After which, the top piece of 1/32 balsa sheet to complete the stabilizer.
The Pod is then glued with the Boom. At this point, the horizontal alignment of the wing saddle and the horizontal line of the stabilizer is not 100% critical. Just make sure that the angle is zero to each other as possible.
With the Pod and Boom assembled, next, I worked on the firewall. From the mistake I made with the first piece, I made the second one about 2mm bigger in diameter. As the motor is on the inside of the firewall, I need to make a recess for the 3 wires so that it would not be rubbing with the rotating part of the motor.
The top piece of the front housing was stacked with a few pieces of balsa and then sanded to the shape of the firewall. The bottom 2 corners were filled with balsa fillet which extend all the way back to the wing TE former.
The firewall was then dry-fitted and then glued in place.
more work expected next......
MS
MS
