micro hpi rs4
    micro hpi rs4
    wanna use cheap esc and brushless
    any recommend???
    any recommend???
    You can try bidding for this . Offer him USD$38.
    For BL motor, you can try the 130 range from rotor .
    Those above are cheap examples only. I haven't tried them myself but ppl has used them with success. I have the Mamba system. IMO, you should get it. Peace of mind.
      but manbo will cost me 180 leh
      hoefully i can have all the esc and brushless for around 100 or less...
      anyway, i only wish to make the car moveable.
        how about this:
        http://shop.rotor.com.sg/show-detail.asp?prodid={5AADD503-66C1-42D9-87C3-FA2172CE02A2}
        seems cheap with selectable brake.............
          If just need to be moveable, no need brushless liow.
            how about this:
            Er....that's a plane ESC. And the 'brake' is not the braking you have in mind. Anyway, you'll need at least 25A for the micro.
              it is because:
              after a long rest, the micro esc and the up-grade 43T 180 motor has not enough power
              to push the car....
              i dun know if the the esc or the motor is bad.........
              after i assemble the car again too make sure...
                finally, the car is moving slowly liao
                after changing the motor..... which cost me 40plus from tai sing
                Is there still pple playing micro rs4 now???
                its been a long time after a race at expo...
                  LOL no need to offer $38. I offered $35 only. Maybe u wanna try 30?
                  Anyway I m using it. I have 2. The first one died after I left my lipo connected to it overnight..... Dunno how it died but my lipo surived. 3S dropped until 3.7V. No Bloating. Charged it, back to normal voltage and output and duration still as powerful as before.....
                  This one got 2 brake setting. The ABS brake is very violent. I would suggest using the proportional brake. It will be lighter on the gears.
                  This esc is prone to cogging if your gear is not correctly ratio-ed. It also glitches alot. The car will occasionally go out of control for a split moment. (Dunno if it is bcoz of my lousy stock mini lst radio).
                  I wanna know how this brushless esc compare to the quark 33A Pro car? Any feedback?
                  Esky Dauphin
                  Walkera Lama 2
                  Walkera 5G6
                  Brushless Micro-T
                    Another cheap one.
                    Esky Dauphin
                    Walkera Lama 2
                    Walkera 5G6
                    Brushless Micro-T
                      Bugger it!
                      Anyway, I've not much faith in it's quality as compared to CC. Still haven't got to use mine yet.
                        Bugger it!
                        Ehh wat is CC?
                        Esky Dauphin
                        Walkera Lama 2
                        Walkera 5G6
                        Brushless Micro-T
                          Ehh wat is CC?
                          It's Castle Creation. Mamba.
                            U got try quark 33? I heard very good reviews abt it
                            Esky Dauphin
                            Walkera Lama 2
                            Walkera 5G6
                            Brushless Micro-T
                              Got but still NIB. I was looking at the manual and the programming steps. Then decided not to use the ESC as I got a bit confused.
