Hi! I have a Kyosho twin storm running on stock motor. I am using a GP 7.2V 3300mah NiMH Battery pack. The battery ran out very fast. How can i improve it or any other solutions. Thks!
Twin Storm
Originally posted by BL4Hi! I have a Kyosho twin storm running on stock motor. I am using a GP 7.2V 3300mah NiMH Battery pack. The battery ran out very fast. How can i improve it or any other solutions. Thks!
What ESC are you using?
Originally posted by BL4where can i get and how much does it cost. I am using stock for my ESC bascially my whole Twim Storm is stock. Thinking of upgrading the motor?
Upgrading motor? Your biggest headache will be the ESC, you will need one that is small enough to fit the radio compartment and at the same time power two motor.
I blew my Kyosho stock KA6 ESC, could be over prop as I fitted a 47mm prop instead of the stock 42mm. Stock prop is slooooowwwwwww.
I then use a HK made Apex ESC but it is not delivery power to my servo at full speed. As such I cannot make direction changes while at full speed. Also kena thermal shutdown...sigh....
Next ESC will be the Mtronics Super E truck that my friend is using and constanly outrun me.....Mine arrived last month, just no time to put it in.
Originally posted by AdrianliUpgrade to a brushless setup, then u will dump all those brushed motors.
Originally posted by SG VillainYou should be able to get them at most good hobby shop. GP4300 is around $89.00 a pack, you will need 2. I got mine from TaiSing. I avoid IB cell, so much problem....some good some complain...I also dunno what is right.
